Recommend single tube reverb? No inductors allowed, just one tube
brewdude
Re: Recommend single tube reverb? No inductors allowed, just one tube
Post by brewdude »
SoulFetish wrote: Tue May 26, 2020 7:55 am So, I've shared this over at MEF, but this is a 1-tube (abbreviated) reverb circuit I designed to retrofit into my buddy's Silvertone 1474 to replace the stock one.
Inspired by Channel Roads article. Mine uses 6U8A 9-pin pentode/triode tube. Personally, I prefer a direct CCS driven reverb to most all transformer driven reverbs.
Will you please explain the recovery circuit?
What are the spec's of the reverb pan?
TUBEDUDE
Post by TUBEDUDE »
I believe the Carvin Belair, and VT-50 uses a one tube reverb, and is transformerless also.
SoulFetish
Post by SoulFetish »
brewdude wrote: Wed May 27, 2020 1:36 am Will you please explain the recovery circuit?
Sure. So, the recovery circuit is a hybrid cascode. It leverages the high transconductance of a semiconductor (a JFET in this case) to drive the current through the top triode to achieve very high levels of gain. In this way, it’s similar to a traditional all tube cascode. Even though there are some operational differences, Merlin has a article which gives a good overview of designing a traditional all tube cascode here:
http://www.valvewizard.co.uk/cascode.html
I recommend giving that a read to start.
I opted for a "hybrid" approach because the project presented a couple of challenges;
First, in order to keep the amp architecture and function true to the original design, I only had one tube position to work with. The 6U8A pentode section of the tube was ideal for the driver, but a recovery stage requires very high gain and low noise. Unfortunately, the triode section of the tube is a low/medium mu–high gm type, and is not well suited for this type of task.
It was so frustrating, because all I really needed was just one more friggin' triode stage to give me a few different options to get the level of gain I needed. But, it wasn't an option without it causing wholesale changes to the rest of the amp. When faced with the prospect of drill out the chassis and installing another tube, or squeezing every last drop out of that single triode and settling for a voltage gain of 22, I said fuck it, I'm cheating.
I started thinking about different kinds of hybrid circuits I'd seen used in other applications. I remembered seeing various hybrid cascode combinations popping up from time to time, but I really didn't have any experience with them previously. I started searching out examples, and discovered that using a jfet as the input stage, and transconductance amplifier in the lower section of a cascode has a lot of advantages. Using it in the recovery amplifier of a reverb circuit, it's almost ideal. The LSK170 jfet in my example is legendary for its low noise characteristics and is uniquely well suited in this application.
Single stage. Very high voltage gain. Low noise. That with the fact that I don't even need to provide a separate low voltage supply for the fet makes it like the perfect cheat code here.
Does that answer your question? I'm not sure how in depth you wanted me to get as far as choosing the right jfet, the saturation region, how to draw up the load lines, etc
SoulFetish
oh yeah, the tank I chose was model 9EB3C1B.
It has a long delay with a Zin of 800Ω and an Zout of 2575.
The one thing I would do differently is to use the medium delay tank. The long delay mounted in the 1474, even with a reinforced cabinet, can be susceptible to acoustic feedback and cause instability.
brewdude
Post by brewdude »
Thank you.
