huh? #183 is plexi marshall 100w OT made by pacific, magic parts plexi replacement for choke and PT... unless the layout is not accurate info, but i doubt that... so you just need to use whatever 50w plexi trannies you like. lower the power supply, so no 330uf.. and your good to go.Guitarman18 wrote: ↑Sat Apr 07, 2018 9:39 am Wow, that is a thing of beauty - well done!
I've always wanted to do a 50W #183, but have always wondered what to do about the trannies. As the original #183 used out of spec Twin iron running a quad of EL34's, surely if you did a 50W version you would have to factor in the out of 'specness', to get the operating characteristics right. Taylor, did you use a Classic Tone Bassman OT to run your EL34's, and a custom Heyboer? If so, could you tell us what you requested for the heater current capability etc?
I'd really love to hear some clips!
Paul.
#183 Build 50w
hitchcaster
Re: #183 Build 50w
Guitarman18
Re: #183 Build 50w
hitchcaster,hitchcaster wrote: ↑Thu Jul 18, 2019 1:28 pmhuh? #183 is plexi marshall 100w OT made by pacific, magic parts plexi replacement for choke and PT... unless the layout is not accurate info, but i doubt that... so you just need to use whatever 50w plexi trannies you like. lower the power supply, so no 330uf.. and your good to go.Guitarman18 wrote: ↑Sat Apr 07, 2018 9:39 am Wow, that is a thing of beauty - well done!
Paul.
Yes, I realize that now. There was a point in time, before the details of #183 were widely know, where members speculated that Twin trannies were used. I just hadn't updated my knowledge to include the correct details.
Apologies to anyone who was confused by my post.
Paul.
'Beauty is in the ear of the beholder'
hitchcaster
Re: #183 Build 50w
no worries.. did you ever attempt the 50w 183? ive been thinking about it.Guitarman18 wrote: ↑Thu Jul 18, 2019 11:26 pmhitchcaster,hitchcaster wrote: ↑Thu Jul 18, 2019 1:28 pmhuh? #183 is plexi marshall 100w OT made by pacific, magic parts plexi replacement for choke and PT... unless the layout is not accurate info, but i doubt that... so you just need to use whatever 50w plexi trannies you like. lower the power supply, so no 330uf.. and your good to go.Guitarman18 wrote: ↑Sat Apr 07, 2018 9:39 am Wow, that is a thing of beauty - well done!
Paul.
Apologies to anyone who was confused by my post.![]()
Paul.
Re: #183 Build 50w
So much (mis)information on this amp. I am using a Hammond 320-0-320 volt PT and a 4.2k Ω/60watt output transformer on my build .
I know that it should be in the 3k range. What will be the effects on the overall sound? Your help will be greatly appreciated .
