Adding a Slope Control
Hi all,
I've seen several versions of it but no-one has a slope control.
I think this amp could gain alot of versatility just adding a push-pull slope control:
- the push-pull adds a 240pf paralleled to standard 240pf in the tonestack
- the linear 100k pot is added in series to a 22k instead of the classical 33k/100k slope eq resistor.
What do you think about it?
Re: Adding a Slope Control
Sure, why not.  Give it a try, and let us know how it sounds.
--mark
 Give it a try, and let us know how it sounds.--mark
Now I'm working on a 100w 4ch head and some similar tricks on it, so until February I can't star a new project. I would like to know just some experiencies about it. ..have I to patent this idea?
Patent a potentiometer in series with a fixed resistor to vary the slope value? This trick is used extensively throughout the test & measurement world. When a part (usually a resistor) changes too far from its nominal value, a potentiometer is in series to bring that portion of the circuit back into specification. It’s a good idea, but you'll never get a patent for something so old - it would be like trying to get a patent on biasing a 12AX7 with an RC circuit.roberto wrote: ...have I to patent this idea?
I use this method all the time in the custom builds I make for clients. I have several strategically placed fixed series/ variable pots placed in my work mule chassis (that and switchable caps to see which voicing they prefer). Once I find a certain value which sounds good to them, I simply measure it and replace it with a fixed value.
FWIW ...
-Greg
Greg,
Obviously I was jocking! I put a big " ".
My reply means: why in a Trainwreck forum nobody thought about add versatility to the amp in such a simple way?
 ".My reply means: why in a Trainwreck forum nobody thought about add versatility to the amp in such a simple way?
Roberto,
I guess that's what I get for reading this stuff and responding so early in the morning
Doing what you suggested & what I presently do is the only way to really zero in on voicing the amp quickly without soldering/desoldering. I have a varible configuration in the PI (tail resistor), NFB loop and slope resistor along with switchable caps in the tone stack (go from 0.022 to 0.01uf). Makes life easy!
 no problem at all!
  no problem at all!Thanks for your help, hope to see other people on this thread.
I think this could be a great pot between gain and eq.
I think to open a thread in a couple of month about a trainwreck based amp with some tricks.
Keep in touch, I'll need some help!
I take a lot of information from this forum so I like to give back when ever I can.
-Greg
						-Greg
this (resistor with series pot) was used on a marshall model in the 80's i believe----the schematic for the model is in the doyle book.   i've done this a couple times myself over the yrs. ----in the right amp it's pretty cool.    rh
I made several "tweaks" using my test mule. This is one I just shipped.
Now it's in MP3 format ... give it another try ..
jerrydyer,
does this mod is on pre-gain-eq amps? Or you do it in marshall-like amps?
rhinson,
I think you talk about valve-state's contour. Isn't it?
gcenker,
I can't play that file. Renamed with mp3 extension, doesn't work.
rhinson,
gcenker,
Roberto, try it now ...
-Greg
						-Greg
I'm in a VALVE-STATE of mind
scnr
Ciao
Martin
 scnr
Ciao
Martin
hi
Mine are like marshall clones i guess tone stack is like  2204 type thang.. there is no reason why it wouldnt work in a tone stack that is somewhere in between v1a and v1b etc.   Baxandal would be a different story as to I cant even identify the slope resistor in a baxandall. I could guess but???
