Fender Blackface Grounding
				Bombacaototal
I am working on a Deluxe Reverb type build and have a couple questions regarding the grounding.
I am using a Ground Buss bar across the pots which is connected to an earth ground point at the chassis, all input jacks (for both channels) are isolated via washers and the jacks are connected to the Buss bar too. All ground points of the layout are connected to the buss bar except for the Phase Inverter (47K) the 1ohm resistos of each power tube, bias tap,heaters, etc which are using the power transformer ground lug. My amp has an FX loops which also has the isolation washers and is connected to the main Buss bar chassis ground point.
Here is where the doubt arises:
1) I am not using the washers on the footswitch jack and also on the speaker jacks which are "self grounded" via contact with the chassis. Should I use washers for those too and use the power transformer ground lug for the speakers jack and the ground buss earth for the f'switch, or are they fine like this?
2) For the reverb rca jack send/return I am using the washer on the return only and grounding it on the Buss bar earth ground point, while the rca send I am using the same approach of the f'switch and speakers jack and having it in direct contact with the chassis without washers and hence "self ground".
3) I am using the rca jack send ground for the reverb transformer ground, and assume this is fine
Re: Fender Blackface Grounding
Washers for the sockets etc come in 'flat' and serrated' types; usually flat dress washers on the outside, serrated inside. It may be useful to clarify exactly how you've arranged this.Bombacaototal wrote: ↑Wed Aug 29, 2018 9:14 am...I am not using the washers on the footswitch jack and also on the speaker jacks which are "self grounded" via contact with the chassis. Should I use washers for those too and use the power transformer ground lug for the speakers jack and the ground buss earth for the f'switch, or are they fine like this? ...
				Bombacaototal
Thanks for the note, the isolation washers I am using on the Input Jack, etc are a hard plastic and flat.pdf64 wrote: ↑Thu Aug 30, 2018 8:23 amWashers for the sockets etc come in 'flat' and serrated' types; usually flat dress washers on the outside, serrated inside. It may be useful to clarify exactly how you've arranged this.Bombacaototal wrote: ↑Wed Aug 29, 2018 9:14 am...I am not using the washers on the footswitch jack and also on the speaker jacks which are "self grounded" via contact with the chassis. Should I use washers for those too and use the power transformer ground lug for the speakers jack and the ground buss earth for the f'switch, or are they fine like this? ...
I will check how I did the non-isolation washwers on the pedal jack, thanks for the tip!
FEnder's grounding scheme leaves a lot to be desired. The input and output jacks and reverb rca phone plugs are not isolated. And many preamp stages share the same filter cap and the same filtering.
									www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
I would connect the signal ground buss to the chassis as far away from the transformer ground as possible.
				Bombacaototal
		- JazzGuitarGimp
Are you using flat pladtic washers on both sides of the panel, or does one of the washers have a lip, or shoulder, that fits inside the panel hole?
				Bombacaototal
Indeed those plastic washers where one side has the elevated lip and the other is flat. I must confess that I haven't dirlled all holes large enough to fit the lip inside. Would it make any difference?JazzGuitarGimp wrote: ↑Wed Sep 05, 2018 3:41 am Are you using flat pladtic washers on both sides of the panel, or does one of the washers have a lip, or shoulder, that fits inside the panel hole?
The shoulders on the washers ensure the threaded barrel of the jack does not contact the chassis... BUT ONLY IF YOU USE A PROPER SIZE HOLE. Best to use a pair of these insulating shoulder washers for each jack.
				Bombacaototal
Many thanks sluckey, it indeed makes sense and total oversight from my side. I will have to either drill larger holes or just ground to the chassis then...I appreciate the help
				sluckey
Here's a pic of the shoulder washers that Hoffman sells. Chassis hole must be 1/2". Also, you may need jacks with the long barrel, ie, Switchcraft L12A. FWIW, Fender never used isolated jacks on the old amps we love.
				Bombacaototal
Attached is what I am using. I didn’t realise but I had actually drilled it wide enough for the shoulder washers..only saw once I removed the jacks....this is what happens when you let a build sit in for too long  ...
...You do not have the required permissions to view the files attached to this post.
				Bombacaototal
Is it an overkill to add the star washers on the bias testing points like I did?
I am also struggling to secure the RCA connector given the additional lug I cannot add the star washers. Any advice on how to go about it?
The larger holes are from a much bigger RCA connector which came with the donor amp..I will close those with grommets
[EDIT] not sure why the pics are uploading upside down
						- pompeiisneaks
- Site Admin
It's a bug in the shrinking feature, see it randomly, but when you click on the actual picture they turn back up the right way
				Bombacaototal
Ah ok, thanks Phil!pompeiisneaks wrote: ↑Thu Sep 13, 2018 3:34 pm It's a bug in the shrinking feature, see it randomly, but when you click on the actual picture they turn back up the right way
