Brian, what type of amp did you use for the listening ampmchauck wrote: I built my listening amp.
 It's VERY cool that this setup has already proved its worth. I had a feeling that Dave brought us something very useful
 As they say in Kentucky, you can't beat that with a stickmchauck wrote: Her name is Elvira!!!!! Has all the internals layed out by Mr. Hoffman.
'bout 40 watts. What's the difference, you're only listening for farts and squeeks and stuffdrhulsey wrote:What is the wattage on your stereo ampBob-I wrote: I use the stereo in my little room as a listening amp.
That's true if you're just troubleshooting. As Dave said, you can do "some very serious tone shaping," as well. The stereo amp, being more linear, should give you a truer re-production of the tone of the test amp. I was just curious as to what size amp had worked for you. Until about a year ago, I had a couple of older stereo amps stored in my garage. They would have been perfect, however, they fell victim to a clean outBob-I wrote:What's the difference, you're only listening for farts and squeeks and stuff
 Now, I've got to look for one on ebay
Why buy when you can build:drhulsey wrote:That's true if you're just troubleshooting. As Dave said, you can do "some very serious tone shaping," as well. The stereo amp, being more linear, should give you a truer re-production of the tone of the test amp. I was just curious as to what size amp had worked for you. Until about a year ago, I had a couple of older stereo amps stored in my garage. They would have been perfect, however, they fell victim to a clean outBob-I wrote:What's the difference, you're only listening for farts and squeeks and stuffNow, I've got to look for one on ebay
Thanks for the info
Grack, you know how many projects I got going in parallel?!!LeftyStrat wrote:
http://diyaudioprojects.com/Chip/LM3886 ... 886_CA.htm
I accept yo' challenge, SuhLeftyStrat wrote: Why buy when you can build
 (In my best Southern accent, while twisting my long, white handlebar mustache).
 (In my best Southern accent, while twisting my long, white handlebar mustache).  At least, I can keep it small. I think I'll try a mono kit and use some monitor speakers I've already got. Thanks for sharing that link
