Rectoverb + Deluxe Reverb?
Fender Amp Discussion
psychepool
Post by psychepool »
I had posted a debug request article for Deluxe Reverb.
https://tubeamparchive.com/viewtopic.ph ... highlight=
Despite a lot of people has given assistance to find the cause, but now I give up to debug.
It is difficult to find the problems due to the too narrow chassis.
In fact, there's many recycled parts and it makes the situation difficulty.
So I decided to break it and make it again with new parts.
But I thought it's waste of opportunity that make the same schematic.
So I want to try the other schematic that I didn't experienced.
There are four 9-pin tube chassis holes, and two 8-pin hole is drilled.
I look around many schematics and finally find the Rectoverb schematic.
I planed to add reverb circuit of Deluxe Reverb to Rectoverb rhythm channel.
The clean tone itself is very modern and clear, the overdrive tone with pushed mode is very creamy.
Deluxe Reverb needs crank-up for make overdrive but Rectoverb is no need to set the master volume 10.
The chemistry with vintage styled stompboxes(like fuzz face) is not good than Deluxe Reverb because it is very modern sounded.
But I expect it would be very funny trial.
This is Rectoverb schematic that I found.
http://www.classictubeamps.com/schemati ... ematic.pdf
http://elektrotanya.com/mesa_boogie_sol ... nload.html
And this is Deluxe Reverb.
http://www.thevintagesound.com/ffg/sche ... _schem.gif
So I draw a schematic like this.
http://s935.photobucket.com/user/psyche ... y.jpg.html
It is simply added the DR reverb circuit to Recto rhythm channel.
May be it will operate and can get the sound but it needs optimization.
Because of I'm not majored in electronics, there must be many errors.
So I need your advises.
p.s
I have always sorry for my bad English. Thanks to everyone. :)
