As of right now the cabs are just waiting on front and back panels/baffles pending my friends availability so I can use his table saw haha. Have all the parts for the guitar, just finished applying a tru-oil finish to the neck. Came out looking rather nice. Got the neck and hardware from Warmoth. Picked up a loaded pickguard off of ebay out of MIM Strat. The body I've had for about a decade, got in a guitar shop for cheap, supposedly its made by Might Mite.
Today I ran into some problems however. The pick guard I have doesn't fit quite right. In order to get the lower horn piece to line up the pickguard has to be rotated slightly clockwise which causes the cutout for the neck pocket to overhang slightly. I figured this wouldn't be much of an issue just file it down and it should be good.
Well after doing that and playing with alignment of the bridge I found that rotating the pickguard throws off the alignment of the pole pieces of the pickups with the strings somewhat. Someone had told me the MIM strats are slightly different dimensions. Brought the body up to Guitar Center today, tried a Fender pickguard, same problem.
So kinda at a loss as to what to do at this point, everything I could find on Mighty Mite body's seems to indicated they're built to the same dimensions as Fenders. However this thing is about a decade old so things might have changed. Either they have or its from different manufacturer. Anyways I'm open to any suggestions.
Here's some pics of what I've done so far. Cabs came out fairly nice I think considering it was my first time using a router, and doing it free hand haha. Still have a bit of sanding to do.
[img
[img
[img
[img
[img
