How the 5E3 Deluxe Amp Works
Fender Amp Discussion
robrob
Post by robrob »
I finally got around to completing the How the 5E3 Deluxe Amp Works webpage. With the number of 5E3 kits being sold I thought it might help some newbies understand what the amp is doing. I try to detail how the amp functions and how changing component values will affect the amp's voice.
If you're interested take a look and as always suggestions and corrections are welcome.
https://robrobinette.com/How_The_5E3_Deluxe_Works.htm
Colossal
Re: How the 5E3 Deluxe Amp Works
Post by Colossal »
Really great stuff on your site Rob. You've put a lot of effort in. Well done.
jjman
Post by jjman »
Showing a proper ground on the power cord connection makes sense for safety. Moving the fuse to the hot side of the switch, instead of on the original neutral, would also make sense for the same reason.
robrob
Post by robrob »
jjman wrote:Showing a proper ground on the power cord connection makes sense for safety. Moving the fuse to the hot side of the switch, instead of on the original neutral, would also make sense for the same reason.
Yes, I agree and I'll get around to editing the Fender schematic to reflect that one of these days.
vibratoking
Post by vibratoking »
Cool, Rob. Nice service to the internet world.
deeder
Post by deeder »
vibratoking wrote:Cool, Rob. Nice service to the internet world.
So kewl Rob, it's very educative.
2203/2204-ish/Deluxe Reverb
dcribbs1412
Post by dcribbs1412 »
Nice website Rob
thanks for sharing
layout with signal flow is really cool 8)
D
ampmike
site
Post by ampmike »
My 5e3 is acting up.Just started pulling tubes to see if thats the culprit.All of your work is bookmarked and printed.So very helpfull.Cant thank you enough.Thanks buddy,Mikey
