First let me describe the hum: 60Hz with Volume of both channels all the way down, turning up the volume does not increase the hum, its just always there.Stevem wrote:What things have you done so far to try and cure your hum issue?
Well so far I have changed all the tubes including the rectifier, this had no effect. So then I changed the power supply filter caps, and a few of the power resistors as well (The amp has a 3 wire AC plug with the earth ground connected to the chassis). Still had hum, so I rewired the grounds for most of the amp, kind of star grounded but without isolating the jacks and pots, this seemed to help a very small amount if any at all. To hlep debug I have taken out the two preamp tubes, turned on the amp and still get the hum. I have twisted the heater wires going to both of the power tubes, still hum.
I was thinking of re-running the ground wires in a different configuration, kind of isolating each ground stage in the system with a separate connection to the chassis. Some of the hookup wire in the amp I think is from the original build, maybe I should use new wire?
Also another thought was this: This amp has a circuit board. So the heater voltage going to the preamp and phase inverter tubes travels on the board, maybe it is causing noise on a signal trace somewhere?
Maybe I should cut the heater traces and run twisted pairs to the preamp and PI tubes...
