Transformer selection for SSS type amp
				beasleybodyshop
Hello everyone, im starting to gather materials for my SSS type amp, and I was wondering:
Ive seen people use a fender twin set of iron for these, but is this optimal in terms of B+? I was considering going with some custom Heyboer iron this time around, and was playing with the idea of lowering or upping the B+ from the 640 range? maybe having one build with a higher ma rating? Thoughts?
						Re: Transformer selection for SSS type amp
IMO..This is totally a personal preference type question?beasleybodyshop wrote:Hello everyone, im starting to gather materials for my SSS type amp, and I was wondering:
If you build enough tube amps you will through trial and error and experimentation begin to draw your own conclusions as to what voltages on certain tubes and output transformers sound and perform best for your style and sound you are after!!
Some prefer certain type tubes to be run at slightly higher voltages..Some at lower voltages..If you are not exactly sure how to make that translation then I recommend sticking with the HAD Spec sheet!!
Always check the tubes max screen and plate voltage ratings!!!
BTW.. Where did you get 640V from?
				eniam rognab
hey buddy
 that's a tall order, SSS (dumble in general) are not easy builds.  im proud that you are progressing as far as you have!!!  im sure it will turn out awesome!
keep it up dustin, you are going places, i can tell/feel the enthusiasm.
please keep us posted, oh and pictures!
subscribed
neal
subscribed
neal
In referencing Twin iron, did you mean 460VDC?beasleybodyshop wrote:and was playing with the idea of lowering or upping the B+ from the 640 range?
for a 100w, I'd try a twin style PT; for a 150w, I go for 500-530v b+ voltage
									www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
Hey, beas, I've got a serious hunk of iron here for cheap. Let me know if it suits your needs.
https://reverb.com/item/71438-fender-to ... 77-project
				beasleybodyshop
I was looking at MCI Iron for a twin, according it its spec sheet its 640V?Colossal wrote:In referencing Twin iron, did you mean 460VDC?beasleybodyshop wrote:and was playing with the idea of lowering or upping the B+ from the 640 range?
				beasleybodyshop
For starters, ive done a very foolish thing and made a chassis out of SS
I want this one to be the best thing ive ever built, period. Im pulling out all the stops (Amplified nation cabinet, custom iron, quad of NOS Tung Sol 5881s, teflon wire, belton sockets, etc etc.) Basically I want to go out with a bang because married life is beginning to take priority for a while and well, i think I owe her that much for putting up with all my amp shenanigans
Ah ok, that is the AC peak to peak on the secondary so 640/2 = 320-0-320VACbeasleybodyshop wrote:I was looking at MCI Iron for a twin, according it its spec sheet its 640V?Colossal wrote:In referencing Twin iron, did you mean 460VDC?beasleybodyshop wrote:and was playing with the idea of lowering or upping the B+ from the 640 range?
320VAC * 1.414 = 452VDC SS rectified
http://www.classictone.net/40-18004.pdf
				beasleybodyshop
Yes. Sorry Colossal, I should have clarified!Colossal wrote:Ah ok, that is the AC peak to peak on the secondary so 640/2 = 320-0-320VACbeasleybodyshop wrote:I was looking at MCI Iron for a twin, according it its spec sheet its 640V?Colossal wrote: In referencing Twin iron, did you mean 460VDC?
er...can you break the maths down for me? I dont understand what your formula is
For solid state (diode) rectification, the rectified DC voltage is approximated by:beasleybodyshop wrote:Yes. Sorry Colossal, I should have clarified!Colossal wrote:Ah ok, that is the AC peak to peak on the secondary so 640/2 = 320-0-320VACbeasleybodyshop wrote: I was looking at MCI Iron for a twin, according it its spec sheet its 640V?
A given PT's AC Secondary x SQRT(2) - (forward diode voltage loss);
SQRT(2) = 1.414;
ex.
320VAC on the MC Twin PT secondary * 1.414 - (0.7VDC) = ~452VDC for B+1 on your Twin OT centertap
If you are using a tube rectifier, the multiplier is dependent on the rectifier tube used. The diode plate resistances in series with the PT secondary create a significantly greater voltage drop than a silicon diode.
A GZ34/5AR4 is about 1.24x the secondary
A (real) 5Y3GT is about 1.00x the secondary
And so forth.
Great looking chassis Beasley! Thats gonna be a beast of an amp. Are your panels Front Panel Express milled aluminum or laser on plastic?
				beasleybodyshop
Thanks for the math, thats good info to know! My faceplates are raster engraved plexiglass. She aught to be a beauty when she is done!Colossal wrote:For solid state (diode) rectification, the rectified DC voltage is approximated by:beasleybodyshop wrote:Yes. Sorry Colossal, I should have clarified!Colossal wrote: Ah ok, that is the AC peak to peak on the secondary so 640/2 = 320-0-320VAC
SQRT(2) = 1.414;
ex.
And so forth.
				amplifiednation
Ha you should turn 1/3 of your house into a gear factory and see how well she puts up with that.beasleybodyshop wrote:Basically I want to go out with a bang because married life is beginning to take priority for a while and well, i think I owe her that much for putting up with all my amp shenanigans
Amplified Nation
www.amplifiednation.com
@ampnation
@ampnation
				beasleybodyshop
Yeah, she wouldnt like that all too much. lol.amplifiednation wrote:Ha you should turn 1/3 of your house into a gear factory and see how well she puts up with that.beasleybodyshop wrote:Basically I want to go out with a bang because married life is beginning to take priority for a while and well, i think I owe her that much for putting up with all my amp shenanigans
Taylor, i sent you an email regarding the cab for this project. Thanks.
				beasleybodyshop
Also ordered a new step bit for the stainless steel chassis. I hope this works, because I can already tell the stainless is going to be a bitch and a half.
