1. On the Fender AB763 Schem from the TAB, the schem says all resistors 1/2 watt unless other wise marked.  Does this apply to pots?
2. What does RA mean on a pot?  A is audio and L is linear, correct?
3. Some pots have more values than just type and resistance, like 50k - RA - 2 - 35 for the intensity pot.  What do the 2 and 35 represent?  I'm guessing watts and something else?
4. Any recommendations for the recto diodes?  I don't even know where to begin there in terms of necessary voltage/current rating.  Obviously I need diodes that can take at least 340v (PT secondary voltage) but how  much margin do I need, and are there current or power ratings involved?
						Twin Build Questions
Re: Twin Build Questions
Check the Schem and Layout for Weber's 6A20..... might have more information.
									__________________________________________
Cheers and Beers.
						Cheers and Beers.
- Darkbluemurder
1. Not sure but in good designs (such as the Twin Reverb) there is no significant DC going through the pots.benoit wrote:1. On the Fender AB763 Schem from the TAB, the schem says all resistors 1/2 watt unless other wise marked. Does this apply to pots?
2. RA = Reverse audio
3. no idea
4. A typical arrangement would be 3 IN4007 diodes in a row. Wiring diodes in series increases the PIV (peak inverse voltage). There are diodes with higher PIV rating than IN4007. 1kV should be good.
BTW I always wondered why tube rectifiers should be more prone to failure than solid state rectifiers. Since I started working on amps (only since December 2001) I have blown 2 solid state rectifiers but never a tube rectifier.
