Alexo wrote:Interesting discussion, as usual...
Reminds me of some debates that take place in the recording community - the human range of hearing extends to about 20khz if you're lucky, yet there are digital recording interfaces that accurately record and reproduce music up to 48khz, even 96khz.
Many people argue that this is a waste of money (and digital storage space), especially since the final medium - a CD - can only produce frequencies up to 22.5khz. But even if we can't hear what's going on at 80khz, you could have an acoustic guitar track and a sousaphone track that are each producing harmonics in that range. The harmonics can interact and produce "sub-harmonics" that do come out in the audible range. But if those upper harmonics don't make it to the mixing board, their sub-harmonics won't make it to the CD, and this can be what  separates a 3-d sounding recording from a flat, 2-dimensional one.
So even if there are other factors that chop down the frequency response of your rig before it reaches your ears, it is conceivable that having good hf response in the amp can contribute to a "better" tone, just as filtering out inaudible switching noise can help avoid audible sub-harmonics produced by the interaction of that noise with the musical signal.
But we could argue all day about how many angels can dance on the head  of a pin. The only thing that matters is how it sounds.
late to the party as usual
Would some one mind explaining the production of audible subharmonics from hf harmonics above (pulling numbers out of hat) 24kHz?
I find this an exciting concept not considered as part of the audio sound stage.
Just didn't dawn on me.
I recall reading that while there are things going on above our normal hearing range, these frequencies apparently still affect us through conduction.
This is why a live symphonic crash makes us shiver with excitement, gives us goosebumps, while the recorded equivalent typically is a bit less thrilling.
I stumbled on this thread looking for film cap piggbacking info with consideration to a tube mic power supply I am cleaning up, and for a couple guitar amps and two power amps.
Looks as though the power amps are the only two viable candidates?
Thanks for a great discussion folks, interesting as always and far less brainwracking than slutty.
