Ripper inspired build
Just finished this. A friend gave me an old solid state amp for parts, the only thing I kept was the chassis. So the parts draw was salvaged again and came out with this. 2 seperate channels, clean and second based on the ripper channel. Have a listen.
Aaron
http://youtu.be/76ousSK4DaI
Aaron
Re: Ripper inspired build
What did you use for a schematic? Was it something like a 100w version of the draft idea? How close to this was it?
With respect, 10thtx
don't you sleep?
Seriously, the track sounds great!
Eric
1949 Zenith, Zenith Toggle Recoil, Zenith 55 & 440
@Jeff - Schematic is close. The two channels are seperate to each other and have one tonestack each. I've done a schematic, just need to change a couple of things to match my build. At the moment I'm running some big bottle '50's Sylvania 6L6's, still sorting out the pre's. Although must say, the amp suits humbuckers over single coils. When I first plugged in I used my strat and thought "nice, but needs some work". Plugged in my Les Paul and it was Kapow!!!!
@Eric - I wish I could sleep when I build! I'm to impatient. How's your SSS build going?
Aaron
Aaron
(answered my own question)
"You feel like you're floating on a football field filled with marshmallows." -Dumble
The filtering on the power supply on all nodes is really high on this one, isn't it a bit weird ?
Yes, quite weird.The filtering on the power supply on all nodes is really high on this one, isn't it a bit weird ?
Finished for now. If anything, I'll change the OD mid pot to an audio taper.
Strat through the overdrive stills sounds terrible! I don't think its a single coil issue, more of an output issue. Here's a clip with a tele.
http://youtu.be/nlnYXuvJYDo
Aaron
Aaron
Aaron, do you have the cap on the Od level pot? If so what happens if you remove it?
I had wired a 47pf in there first but removed it. Sounded to harsh for me.erwin_ve wrote:Aaron, do you have the cap on the Od level pot? If so what happens if you remove it?
Aaron
Schematic
Was fixing up the schematic and decided to make it all switchable. So it could be like a 3 channel amp. I haven't tried it like this, it's late, I'm tired.......
Goodnight,
Aaron
Goodnight,
Aaron
