Will the common mods that are done to older black and silver face Fender Vibro Champs apply to a Mojo Kit Vibro Champ?
Changing the bias cathode resistor from 470 to 1k watt and cap to 50uf/50v and putting 1k screen grid resistors are the mods im thinking of.
I know the bias mods are common because Fender started using Princton power trannys in the Champs. But are the modern MOJO kits featuring a corrected voltage or is it still to fender spec?
Thanks for any help
Brad
						Vibro Champ mods for MOJO kits?
Re: Vibro Champ mods for MOJO kits?
If this is a 5F1 Champ, they were designed back when the wall voltage was 110vac.
It's about a 8.7% difference.
You may know this.
So expect the B+ to be a bit above the designed or schematic voltage.
So if the amp was built for 110vac then the B+ should be about the same percentage as the 110vac.
I believe that a change from 470K to 1K will be a bit of a colder bias.
But you should always experiment with different values until the power tube either redplates or sounds gorgeous.
You may know this.
Its a AA764 Vibro Champ
PT specs are
						PT specs are
I guess what I should say is..........Dose anyone know the B+ voltage on a original blackface AA764 power transformer?. Having trouble finding it on the internet.
Thanks guys
						Thanks guys
Heh, im an idiot. They are maked on the fender layout...........
Sorry for the interruption...
