BNP accepts Corel Draw files and Adobe Illustrator files.
So what software are you Mac guys using to provide the artwork to BNP?
						BNP Laser - Faceplate design for Mac guys
Re: BNP Laser - Faceplate design for Mac guys
I use Illustrator, though I'm sending art to PanelCraft Inc. Great product, awesome service, inexpensive (less than $20 per plate!).
I have created panels in PowerPoint and saved as .pdf, and that has worked fine for me with BNP. I used standard fonts, except for a little lightning bolt shape I drew. Check with them to see if they can still do that.
Illustrator is pretty pricey for a twice a year need
I was using Corel Draw in a Virtual Machine, but that isn't working for me anymore, and I'd really like to use a Mac app. But need something on the cheaper side.
Late reply, but perhaps useful:
Inkscape
Good software, freeware, Mac version available, saves .svg files which are supposedly imported by Illustrator. I'm not sure if it would fit BNP standards...
I gave up the expensive Corel for the free Inkscape and never looked back.
									Inkscape
'This is so cool I have to go to the bathroom!' Calvin
Thanks. Unfortunately Jeanne is avoiding Inkscape SVGs as they were problematic for her.
I landed an old, outdated version of Illustrator, and will give that a whirl.
- Milkmansound
Inkscape works for me
Export as EPS and make sure text is converted to paths and they'll work well for you
- JazzGuitarGimp
I am not doing panel art, but I'm successfully running CorelDRAW X4 as a VMWare fusion v5, Windows XP virtual machine on a Mac Mini running OS X 10.8.5
