Supro Amp brand relaunching in 2014
Re: Supro Amp brand relaunching in 2014
Fender didn't dig too deep they found the correct material on the George Benson Deluxe but in gray.
I once found some Italian cloth called snowflake in white with black accents that matched. Retro grille cloth is easier to find.
http://www.pallastextiles.com/patterns/ ... =508&cat=1
Ken Watts Turretboards.com also has 3 Supro kits so I wonder if he will change that to Valco?
Smokebreak
Post by Smokebreak »
M Fowler wrote:Fender didn't dig too deep they found the correct material on the George Benson Deluxe but in gray.
That's a good link. Check the Hendrix bit at the bottom ... I've been looking at vinyl wallpaper hired hand is right there's a lot I could see on an amp.
Yea I had heard that the first amp companies hired out luggage companies to build the first boxes, thus suitcase amps
funkgang49
Post by funkgang49 »
Anyone know where to find the schematic and layout for that Supro 1688tn in the video?
Default
Post by Default »
I was in a hotel recently where the sofa had a tweed covering that was a dead ringer for that Supro covering. I betcha you could order something "close enough" from a furniture recovering place.
If it won't kill me by taking it into the bathtub, I don't want anything to do with it!
funkgang49
I can't seem to find any specs on this Supro model - anyone know where I can find some info? Would it be under the Valco name with a different model designation?
funkgang49
Thanks MM! You da man!
