Anybody try a .022uf bass cap?
If you have, how'd it sound?
Re: Anybody try a .022uf bass cap?
Guess that's a "no". Maybe I'll give it a try and report back.
chris_sanford
Hi Tim,TimS wrote:Guess that's a "no". Maybe I'll give it a try and report back.
What are you planning to use for a mid cap when you switch to the .022uf for bass? Standard Dumble-style TS, or...??
chris
Not sure. I'm planning on making both the treble and mid caps switchable, but I haven't decided whether to install 3-way switches or to just use push-pull pots for the mid and treble controls (I'd prefer switches but I don't have the tools to make the necessary holes). If I go with the three-way mid switch it'll be .05, .02, and .01. If I go with the push-pull pot it'll obviously be two of those three, but I'm not sure which ones.chris_sanford wrote:What are you planning to use for a mid cap when you switch to the .022uf for bass? Standard Dumble-style TS, or...??
As for the bass cap, I don't know whether it would be worth making it switchable or if I should just use one or the other. It seems to me that the difference between the two would be great enough that each would require a different value pot to optimize the control range. But then, I don't believe I've ever heard a post-Tweed Fender with a small bass cap, so I don't really know how it would work (hence this thread).
chris_sanford
Tim,TimS wrote:As for the bass cap, I don't know whether it would be worth making it switchable .chris_sanford wrote:What are you planning to use for a mid cap when you switch to the .022uf for bass? Standard Dumble-style TS, or...??
The bass cap with the Dumble stack should be pretty-much bandpass (imo). Make it smaller than your mid cap for instance, and the bass control will become a midrange control (and vice-versa!). Now if you are using a Fender/Marshall type stack in your amp, then I could see the value in making the cap switchable.
chris
- Funkalicousgroove
Listen to a Wreck, The Express uses .02 for bass and Mid with a 100K slope. (there are some clips on youtube)
I tried it in a D with the 150K slope and changed it back to .01/.1 IMMEDIATELY. Not my cup o'tea, your miles may vary.
chris_sanford
B,Funkalicousgroove wrote:Listen to a Wreck, The Express uses .02 for bass and Mid with a 100K slope. (there are some clips on youtube)
When you tried 'wreck values, did you rewire the mid pot to be in series with the bass pot? I think it sounds pretty good with a 47k-ish slope res.
chris
- Funkalicousgroove
This was years ago before I knew about the "BM" amps. I was just experimenting!!
I will try the other flavor at some point, are you using the .001 OD1 coupler? Is it really thin?
chris_sanford
Yeah, that one sounds ok to me, as long as you use the rest of the circuit as written (except for the extra cap between OD2 and the ts... I think that one must be a mistake!).Funkalicousgroove wrote:This was years ago before I knew about the "BM" amps. I was just experimenting!!
chris
