I'm looking at the ODS-101-HRM print and just want to know about the network in front of the OD 1st stage. It is a 47pf || 470k, feeding a divider network of 200k - 25k pot- 4.7k - gnd
What does this do and if you wanted to have a switchable OD tone stack, would you still use this setup with the tone stack switched out?
Rut
Question about the network feeding OD stage 1
Re: Question about the network feeding OD stage 1
Did you get my PM?? Just curious....
Btw, that network is always there when OD is on. It is a voltage divider with high-end preemphasis.
Just replied
