getting logged out constantly
OK I keep getting logged out even if i switch pages here. my cookies are enabled. i use firefox. i wont use the other. anyway. I can build these things but when it comes some the function i dont get it. Any ideas. just happened again while typing this.
						Re: getting logged out constantly
What do you have in V1 ? Oops Sorry.
Does it happen when you are using a different pc/mac/smart device ?
Good Luck,
Bob
Good Luck,
Bob
Why Aye Man
It logs you out while you are already logged in?
I know this is simple, but do you have the check box by your login checked?
Other than that and cookies enabled, not sure what else there is unless your ISP is changing the DHCP rapidly.
Do you have this problem on any other site or forum?
This the only pc i have used to be on this forum.
Checked, unchecked hasn't made any difference. I havent been to any other forums in months, so i really cant say. I'll just keep messing with things.
Thanks.
Thanks.
Using chrome at work if I double tap the TAG icon too quick it will boot me out.  If I single tap seems there to be no problem - I just figured that it had something to do with our network police here...
It was working good so far this morning until a minute ago. F'n pcs
There also may be some maintenence being done on the new sections which may take it offline for a minute or so.
I had to login this morning, usually I just click my shortcut and the forum pops up and I'm logged in.
Just wait a bit for the dust to settle, I'm sure it will straighten out.
Ok, it is working far better than yesterday i must say.
