My Handmade "Bluesmaster/RIPPER Reverb" video
richon
Post by richon »
Hi,
Here is my bluesmaster/RIPPER with reverb amp
Its almoust ready
Greetings from Chile
http://youtu.be/rYkZ1L120oc
Soy de Chile y tu?
Re: My Handmade "Bluesmaster/RIPPER Reverb" video
Soy de Oregon. :D
Su amplificador suena bien.
Podemos ver algunas fotos de ella?
¿Es difícil encontrar piezas de amplificadores allí?
bluesfendermanblues
Post by bluesfendermanblues »
Sounds really good!
richon
Post by richon »
Structo wrote: Podemos ver algunas fotos de ella?
Si cuesta bastante (pero la mayoria es importada)
I use Classictone for all transformers and I was pretty much shocked about how good they sound over some "other" famous transformers
Some Pics:
[img:640:480]https://dl.dropbox.com/u/112924595/Cabl ... k%2010.JPG[/img]
[img:480:640]https://dl.dropbox.com/u/112924595/Caja%204.JPG[/img]
[img:640:480]https://dl.dropbox.com/u/112924595/Dumb ... lo%201.JPG[/img]
[img:640:480]https://dl.dropbox.com/u/112924595/Sold ... edneck.jpg[/img]
Soon more pics and videos
Its a modified Bluesmaster preamp, into a Ripper kind of OD channel into a one tube Reverb into a Fender Power Stage with Dumble Presence mod
Soy de Chile y tu?
richon
Post by richon »
So I changed the eq of the RIPPER (2nd Channel) from a jcm800 like into a bassman/jtm And BOY IT SOUNDS GOOD NOW
I,ve found that this is a 2 Clean Channel amp:
First is more a blackface sound
Second is more a tweed Overdrive sound
Both sound awesome
I,ve even added a switch for bypass the third stage cathode bypass resistor (820R) with A: none, B: 680n, C: 2,2uf for different tastes of bass/Fat/fuzzy bass notes
Soy de Chile y tu?
greekie
Post by greekie »
Do you have a schematic for this amp? Or one you started out with?
Looks interesting!
10thTx
Post by 10thTx »
Look at the second page of this thread & it has schematics and even references some editable SCH versions of the schematics:
https://tubeamparchive.com/viewtopic.ph ... c&start=15
Please NOTE that the schematics are a draft "idea" and not based on actually seeing a Ripper amp.
with respect, 10thtx
10thTx
Post by 10thTx »
Richon,
How close is your amp to this schematic (IF you're willing to share?)
I attached an editable version that you can alter IF you want to.
With respect, 10thtx
richon
Post by richon »
standard bluesmaster preamp...
but 2.2K cathode first stage, 68K slope resistor
OD: 470K/470pF insteak of 470K/47pF
Power/PI : Fender based , not the Marshall values in NFB
this so far...
maybe some minor mods will come later , like bright caps in the masters volume in each channel... but it seems it isn't necessary
or different bright caps on first EQ.... i guess so
also maybe some values to the mixer of the reverb
PS: 500pF in the second stage (recovery) from grid is to have less highs from it?
Soy de Chile y tu?
richon
Post by richon »
well,
the OD channel (the 3rd and 4th stages) well completely dumped... redesigned
I went with the OD way of overdriving the signal ... but changed the coupling caps and also (very important) the CATHODE resistors into a Trainwreck-ish third stage and a simple fourth stage , which in results gets me into more distortion than OD (which I kinda like)
Soy de Chile y tu?
Bob-I
Post by Bob-I »
I was thinking it sounds great, but not Dumble-like, then I read the rest of the thread. Very cool design, sounds unique.
