[img
[img
Seriously? Does the OT orientation make a difference noise wise?briane wrote:.....
9) first fire up, orient OT for least humm, install and wire (use current limiter)
neither am i!heisthl wrote:I'm not familiar with that step.nickt wrote:Good approach - but you left out the last step:
17. cry/curse/swear/wimper when it sounds like crap
Thanks for that..Structo wrote:Great pointers one and all!
If the first timer doesn't all ready have one, I suggest as a first step to build an amp cradle.
It really helps working on a chassis.
Maybe not at first since you are flipping that box around a lot but for wiring and working on a built amp they are indispensable.
I think I copied AmpDoc's cradle when I built mine but later had some other ideas.
The locking arms are great so you can have the chassis at any angle you wish.
And since the chassis is really an unbalanced load due to the transformers having the cradle hold the chassis securely is key.
Brandon (AKA Funk) has sworn-off TAG as far as I know. The "death cap" is the 0.05uF switchable from one mains supply leg to the other. This was a common feature on Fender designs dating from the 1950's to reduce noise. If the cap shorts and the switch is in the wrong position, the chassis is connected to the mains, hence the name.noworrybeefcurry wrote:... but what is the "death cap"?
Funkalicousgroove wrote:I go about things a totally different way, Having built 20 of these in the last 12 months, I really think I have it down to a science, It goes together easily, and takes less than 30 hours start to finish this way. I start from the outside walls, and things along the floor and build up and in:
1. Mechanical assembly with screws, threaded stand-off's, tube sockets, Terminal Strips, and ground lugs first. If you install the transformers first how do you get the screws in that are under the transformers? why do you want to build with all that dead weight? leave them out until it's time to wire them so that your chassis can be easily manipulated
Build your boards, and connect all the leads to the boards with an addl 1-
2" of lead just in case, since the screws are already there, hold your boards in place to make sure you get long enough leads BEFORE you clip![]()
2. Install relay supply board, route wires along the back of the chassis- these are the longest runs of wirein the amp. Install and wire footswitch jack, manual/pedal switches, also wire up the voltage regulator and pilot lamp on the "Lamp end".
3 Install Bias supply/ rectifier board, and bias pot. Route wires along the relay switch leads, bind together with zip ties, leaving an area unbound to attach the output of the bias pot to the preamp board later.
4. Install OT and Choke, Wire power tube sockets: Screen grid leads first, plate leads, cathode resistors(or wire if you don't use 1ohm's to ground), pilot lamp power assembly, screen resistors, grid stopper resistors & Bus, attach OT plate leads.
5. Install FET board with Power lead(leave extra length for routing).
6. Route shielded wires: If you are using coax solder the shields to the back of their respective pots, if you are using foil shield Install the pots and ground bus. Wire the input jack.
7. Wire the switches, pots, and PAB relay, Install leads from Relay board grounds to Manual/pedal switches
8. Install the preamp board with flying leads attached, Wire from v1 toward power tubes, then wire the other side of the board starting with the grid leads/ bias supply lead(routing it along the back of the chassis) Wire presence, then master volume. Wire shielded leads for OD Drive and volume, wire tone control leads.
9. Wire channel relay
10 Install power supply board and wire (all leads should be in place by this time and just need to be attached) and wire stand-by switch.
11. Wire Up OT Secondary (This step can take place anytime after v2 and v3 are wired with plate, grid, and cathode leads) Impedance selector, and speaker Jacks.
12 Mount PT and wire B+, Bias Supply, Grounds, and filament LEads.
13. Install twisted filament leads
14 Install power cord and wire Power switch, and fuse holder ( I don't EVER wire the death cap, if you choose to it is your perogative)
15 Install fuse
16. Check all Grounds, and leads for continuity, take your time and go over each lead to make sure it is wired correctly.
17. Plug into a current limiter or variac and fire it up
18 If everything is good, fire it up at full AC and check voltages
19. If everything is good, Install tubes, bias, and give her a listen!
More than 50 ways to skin a varmit far as I can tell!
I miss those guys as well. Between the two of them, that's a TON of expertise we've lost and I know that the vast majority of folks here greatly appreciated their input. I KNOW I did!212Mavguy wrote:I'm really sorry to find out that the Funk is not here more, also Dogears. I learned a ton from their posts, and loved the "no punches pulled" writing style.
