The NFB series resistor works together with the shunt resistor to ground. It's the ratio of those two resistors combined that gives you the total amount of feedback.Dr d wrote:Hi Taylor, I am in the middle of a 4x6V6 2nd gen hybrid build and was wondering why the gnfb resistor is shown as 3k3 when it is shown as 820R on Tonys 2nd gen layout. Did you ever try the lower value? BTW great build which has inspired me to have a go!
So in Tony's layout, the 2nd gen has the typical Fender 820R/100R network, resulting in a ratio of 8.2
In the layout I used the resistor values are 3300R/390R, resulting in a ratio of 8.4, so the two aren't really that different!
I do have some lower values I was going to try, but I am still settling in with the amp and haven't had time to start tweaking...although I do plan to work with it.
Tom - I have the OD relay wired up untraditionally with dual masters (one clean, one OD). I am liking the way it works right now, but might try the global master later.
