Used my new Liverpool build last night at practice. Turned it up to about 8..and used my volume control on my tele for clean to dirty. It totally rocked! So I'm looking for more control and a hands free way to turn my volume control.
I have used in the past a Ernie Ball Stereo volume pedal cause it has the feature to set the heel low volume instead of completely off. Set the heel at the sweet spot for cleans. Is there a better Volume pedal that would work for this..or any other suggestions?
Just had a thought...how cool would a volume pedal with a effects loop be where when you go to heel it mixes in a EQ..so could have a EQ and say a delay or whatever on cleans and it pans out when in toe..
						Volume pedal for liverpool clean to scream
				johndandry
Re: Volume pedal for liverpool clean to scream
cool! I use underdrives quite a bit. Like a reverse distortion pedal. Really its just a true bypass volume knob in a box. If I get fancy I put the 500pf cap across the 1 and 2 pin for bright and make it switchable. An fx loop would be a nice thing with it though.
double post. oops!
