I found an unloaded Ampeg B115 combo on eBay that fit the bill. The Utah fit without trouble, and I installed eight Tee nuts and used stainless bolts to attach the speaker firmly, but without warping its frame.
The final piece of the puzzle was a Weber 6M18 chassis, which I bought from a TAG member. Aside from a little lead dress cleanup, and adding an additional power cathode resistor to bring the amp to spec, it sounded good without modification.
In order to install the chassis into the cabinet, I had to cut half an inch off one side of the chassis, cut openings for the transformers, and drill clearance for the tubes. Finally, I completed the back of the chassis with some clear acrylic.
I've dubbed it the Wampeg 18. Enjoy!
[img
[img
[img
[img
[img
[img
