Cap outer foil connections in Express
- Colossal
Re: Cap outer foil connections in Express
For those that they may find this useful. This drawing has been vetted by Martin Manning for accuracy.
I was just looking at the old version of your layout last night Dave
Thanks for posting the cap orientation for all to use.
This does bring up a debate; however, is it not true that the design of the these OD caps would not have an outer foil? I have tested and did not find any significant difference. Also, Ken F. placed all his OD caps in the same direction as shown in the files section photos of TW Francesca.
I've checked all the ones I've used recently (6PS and 225P) and there is a measurable difference, some more thgan others as has been previously reported.
- dorrisant
Very nice drawing, Dave... Much appreciated!
Thanks for illustrating that Dave. Looks great and much better described as a picture.
I had to crank the amp a bit to hear the difference with the method I used.
Probably worth re-iterating that I could detect a difference when testing my PVC caps too, where the amount of difference seemed to vary. Maybe this variance is something to do with the value or physical size of the cap?martin manning wrote:I've checked all the ones I've used recently (6PS and 225P) and there is a measurable difference, some more thgan others as has been previously reported.
dorrisant wrote:Very nice drawing, Dave... Much appreciated!
No problem guys. Glad it's of use.eazilyled wrote:Thanks for illustrating that Dave. Looks great and much better described as a picture.
