A Mix of #0060 OD100WR/ #183
- David Root
Re: A Mix of #0060 OD100WR/ #183
Looks real good Steve! How are you doing figuring out the 3-tube reverb? I can't figure it out and it looks much different than #13 ODR.
Okay I should have known Tony you had built one or more
What a beauty.
What a beauty.
- glasman
You may already know this trick with the vox grill cloth, but thought I would pass it on for others.67plexi wrote:Working on a combo, Next step the dreaded Vox diamond grill cloth.
Steve.
When I used to install it on cabinets I would soak the cloth in water and then spread it out, while wet, evenly over the baffle and staple. When it dried it was as tight as a drum.
The tie dye that is shown in my avatar was done using the same approach
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
I have done similar but what I did was install it then take a spray bottle of water and spritz the cloth which would shrink a little when it dried and become tight.
Or you can help it along with a hair dryer, but not too hot!
The back side, It loves the EV12S.
This is next.
This is next.
Are you going with the inductor as used on the Sunn Model T Super schematic for the SSS?
Mark, I know nothing on the Sun amp.
I have a .915H inductor.
Steve.
Steve.
Okay, that is close.
The Sunn Model T Super uses a 1hy inductor.
- boldaslove6789
SSS uses a .9H inductor
Greg D.C.
Can you dig it?
Can you dig it?
- glasman
Selected Wah inductors will work as well.
www.glaswerks.com
www.glaswerks.com
"Those early ones had some crazy stuff going on, Cathode to plate feedback, 3 tube reverb, Inductors, 7 tubes in the preamp total- Cool sounding for sure, but not the SRV thing to my ears."boldaslove6789 wrote:SSS uses a .9H inductor
https://tubeamparchive.com/viewtopic.php?p=66063#66063
Max
Do the filters include settings to also boost bass and treble or do they have only settings to attenuate bass and treble?
Peace,
Markus
Peace,
Markus
