Amp chassis cradles?
tooold
Re: Amp chassis cradles?
Post by tooold »
I'm digging up this old thread to see if drhulsey is still watching it... or maybe someone else can answer my question.
I'd really like to make this rack, and I was getting ready to order the Panavise clamps, but - where do you get the pieces on the end of the angled t-track that have the holes for the Panavise? I've never used t-track or a Panavise before, so this may be an embarrassingly obvious question... :oops:
And to make the angled t-track, did you just cut it with a miter saw, or can I find one pre-cut?
Thanks!
drhulsey wrote:This is my new cradle. I borrowed an idea from a picture Noel posted, using a Panavise 376 self-centering vise head on each end. Right now, it's mounted on a T track on the front edge of my bench, but could be made free-standing like my original. The Panavise clamps are about twice the cost of the quick grip type, but it does look less clunky. Length of chassis is not an issue, and it is sturdy.
Obviously, you can get by with a couple of wooden blocks, but where's the fun in that :D
______________________________
http://www.mylescochran.com
I'm not sure what happened to Dr Hulsey.
He hasn't posted in quite a while.
tooold
Post by tooold »
Structo wrote:I'm not sure what happened to Dr Hulsey.
I was afraid of that, Structo. Maybe there are other t-track/Panavise experts who'll offer advice...
husky
husky
Post by husky »
collinsamps wrote:I've had two different styles and they both collect dust these days. For me personally they are more of a hassle than an asset.
That funny, we made like 3 of them for the shop and nobody uses them as well. They are nice but take up room on the bench
______
John Suhr
www.suhr.com
vibratoking
Post by vibratoking »
I don's use mine either. It always seems to be in the way. Dr. Hulsey's looks nice, but it looks like it has major blockage factor when trying to get to the work bench. I think I'd be bumping into that thing all day. Now if it was mounted to the back of the bench I wouldn't be blocked by it and it wouldn't eat my bench top...hmmm
selloutrr
Post by selloutrr »
It's a tough thing, they are very handy for most ampliers sometimes you run into an oldly placed external component that makes it hard to secure the amp safely. I had to rebuild my layout and elevate my test equipment to over come being blocked by the amp cradle while working.
it's handy to have an angle sometimes but most amps can be supported with a couple blocks of wood. if you are worried about scratches wrap them in tape.
My Daughter Build Stone Henge
jelle
Re: husky
Post by jelle »
Yes, they do take up space. I got the cradle first and then designed the bench. Included a solder fume removal system too. But even with the extra space its tempting to let the bench get cluttered and not use the cradle.
I force myself to clean up after every build as I like to put the amp at an angle. It works nicer for me personally.
jelle
Just bringing this thread up page 1 incase people would like to build an amp cradle.
rp
Post by rp »
Kregg wrote:My cradle works very nicely thank you. 8)
[img:640:536]http://i141.photobucket.com/albums/r54/ ... G_0990.jpg[/img]
Joint project by Ampeg, Fender & Marshall? Tough economy!
malt
Post by malt »
I'll tell you all my secrets, but I lie about my past.
JoeCon
Post by JoeCon »
Very nice! Are those custom made parts?
I think you could build a similar jig with 80-20 parts.
malt
Post by malt »
Made most of the parts from alu and ss steel . I cut the alu parts on a table saw ss parts was made on metal-lathe. The plastic handles is from a office chair and a metal pipe .Got the idea from some pics poster on the hofman board years ago. Made it from parts I had laying around home and at work.
