Phaez Daisy Cutter
Phaez Daisy Cutter
Phaez Amps is coming out with a little amp kit.
A single ended affair with a master volume.
It has been talked about quite a bit at My Les Paul forum and Gear Page.
I was wondering if anybody knew what circuit they are using?
http://www.phaezamp.com/ampshop/en/amp- ... 0-kit.html
[img:600:600]http://www.phaezamp.com/ampshop/31-90-t ... 10-kit.jpg[/img]
[img:600:600]http://www.phaezamp.com/ampshop/31-89-t ... 10-kit.jpg[/img]
Clip:
http://soundcloud.com/ontariomaximus/ph ... 0-guitar-1
Found an assembly tutorial so that explains most of it.
http://www.youtube.com/watch?v=qumL2poI ... e=youtu.be
Deric
Re: Phaez Daisy Cutter
Post by Deric »
Not sure how close the single ended version is but there is a schematic (verified by Randy) over at AX84 (under Associate Projects). I built a budget version of it - cheap Hammond chassis, MPS transformers and whatever parts I could scrounge from the bench. Great sounding amp - tons of fun to play!
8)
Deric®
diagrammatiks
Post by diagrammatiks »
drew out some of it. it's 4 straight gain stages.
can't read the grid stoppers.
anodes are
220k/.0047uf - 150k/.022uf - 91k/tone stack - 100k/.022uf
cathodes are
3k3/2.2uf - 4.7k/.22uf - 820 - 1.8k
surfsup
Post by surfsup »
Looks like a zobel.conjuctivefilter on the output? Looks like 100k on v2
Deric
Post by Deric »
Here's the 2 x el84 version....
Deric®
Bob S
Phaez
Post by Bob S »
Randy's amps do sound amazing. I have 2. The DaisyCutter does sound great with a strat. You cant argue with your ears...
Why Aye Man
ampmike
Post by ampmike »
Hey Tom,Stupid guestion, but is that round puffy thing the output tranny or some type.Ive seen these a lot over the years and never understood what they are,Thanx Mikey
Gibsonman63
Post by Gibsonman63 »
http://en.wikipedia.org/wiki/Toroidal_transformer
Toroidal transformers are coming in a lot of equipment these days. That's what makes it possible to make a powered mixer with 2 500W power amps weigh in under 25 pounds.
Thanks Deric.
Anybody have the single ended version?
@ Mike,
Yeah it's a toroid power transformer.
Supposedly superior is some aspects.
Hi Fi guys seem to use them quite a bit.
Supposed to be quieter as well, no buzz from the core and a big time weight savings from no core.
The clips I heard of the Daisycutter were pretty amazing.
Post by Mark »
It seems like Phaez Engineering is toast.
Yours Sincerely
Mark Abbott
amptone
Post by amptone »
