TR Bassman conversion
brentm
Post by brentm »
Guys - here's an amp that was modified by Joe at TR. I purchased it from him several years ago. I really like the tone of both the clean and the lead channels.
Tubes
V1 - Amperex 12ax7
V2 - Amperex 12ax7
V3 - RFT ECC83 (effects loop)
V4 - Chinese 12ax7
V5 & V6 - JAN Philips 6L6WGB
brentm
Re: TR Bassman conversion
Post by brentm »
More photos
brentm
Post by brentm »
More
Man, I expect better building practices than that from the TR boys.
All that red wire going every which way.
Is the amp very noisy?
brentm
Post by brentm »
No it's dead quiet. I mentioned on another post that I picked up a Custom Reverb... the bassman is MUCH quieter than this Custom Reverb at idle with the post-effect master at noon. The post-effect master will introduce some noise on both amps.
I suppose looks aren't everything when it comes to lead dress. At least that's what I'm gathering. Although a well-lead dressed amp is nice to look at. TR's early amps weren't exactly dressed well.
It did come with the Fender bugscreen as the RF shield on the top inside of the cabinet. It was starting to fray so I replaced it with some sheet metal flashing from home depot.
I do wonder about the steel vs. aluminum chassis...
All in all, this is still my favorite amp.
dreric
Post by dreric »
I'm glad you enjoy your amp. I have a modified bassman from K&M also, it's a good sounding amp. I've seen the blue resistors in quite a few Two rocks, does anyone know who makes them?
Eric
brentm
Post by brentm »
I'm pretty sure they're xicon metal film resistors.
ToneMerc
Post by ToneMerc »
brentm wrote:I'm pretty sure they're xicon metal film resistors.
Yep, from the shade of blue and the width of the tolerance band, it's looks like Xicon.
Bob-I
Post by Bob-I »
I'm with Tom on this one. It really looks like a rush job, soldermblobs all over, leads not cut to proper length or tied down. IMHO this would've onlymtaken the builder another 30 seconds per connection to do "right"
Glad you like the way the amp sounds. These old baseman amps are great mod platforms.
Thx for posting.
brentm
Post by brentm »
Bob-I wrote:I'm with Tom on this one. It really looks like a rush job, soldermblobs all over, leads not cut to proper length or tied down. IMHO this would've onlymtaken the builder another 30 seconds per connection to do "right"
Thx for posting.
Thanks. It's a great sounding amp. No one will argue that it's a bit of a mess to look at.
Anyway, I'm going to remove the photos. Probably best this way...
dreric
Post by dreric »
I sorry to see that you removed the photos. I was going to post photos of my TR bassman mod. Mine looks sloppy but sounds great. Personally, unless the main board has been replaced, I have never seen a mod that looked as tidy as a dedicated build.
I think the new TR look sloppy also. IMO, most true Dumbles look sloppy compared to some of the builds by members. Sometimes the emphasis on the appearance gets in the way of remembering that what the amp sounds like is the most important thing to the player.
Eric
topbrent
Post by topbrent »
If you feel like showing those pics again, I would be happy to see them. topbrent at gmail dot com
dealer: allparts, weber, antique electronic supply
brentm
Post by brentm »
dreric wrote:I sorry to see that you removed the photos. I was going to post photos of my TR bassman mod. Mine looks sloppy but sounds great. Personally, unless the main board has been replaced, I have never seen a mod that looked as tidy as a dedicated build.
Eric
You can still post photos of your TR bassman mod :) Personally, I'd love to see them. If you wouldn't mind emailing them to me, I can get in touch with you.
Yeah, the old "form over function". I had that conversation many times with my ex... well, nevermind :)
Why did you remove the photos?
ChrisM
Post by ChrisM »
Panties got ruffled!
