dumbulator info
jestaudio
dumbulator info
Post by jestaudio »
May well be a pretty stupid question but is this piece of kit strictly nessercery to use the effects loop :?:
Chris333
Re: dumbulator info
Post by Chris333 »
Short answer: No
Bob-I
Re: dumbulator info
Post by Bob-I »
jestaudio wrote:May well be a pretty stupid question but is this piece of kit strictly nessercery to use the effects loop :?:
The effects loop in the Dumble tends to saturate pedals very easily. You can use a line level effect fairly well but at high volumes even that will saturate.
I use a TC Nova delay in the loop without the dulator and it works well as long as I don't really crank the amp.
jestaudio
Re: dumbulator info
Post by jestaudio »
i was hoping to use my TC Nova system as i would with my Traynor custom, i guess its a case of try it and see how well it works :)
Re: dumbulator info
Any reason that you can't just use an attenuator on the send?
jestaudio
Re: dumbulator info
Post by jestaudio »
i may well look at changing the loop to a parallel system sim ilar to the Mesa Nomad i used to use, failing that i am reasonably sure i can use the pre gain on the TC as a limiter of sorts and use the output gain as a makeup, plus the TC has a pretty versatile EQ for tweaking the sound a touch
