Power supply trim Q
markusw
Power supply trim Q
Post by markusw »
Would it work to replace the 22k in the ps string with a 1W cermet trim in order to more easily adjust plate voltage when swapping preamp tubes? I suppose there will be some crackle when turning because of DC but otherwise I guess it shouldn't harm??
Markus
glasman
Re: Power supply trim Q
Post by glasman »
You had better check the voltage and power ratings on the pots.
Given about 440 on one end and 320 or so on the other. You have about
.65 watts of dissipation. Most cermets are in the .25 to .3 watt range.
May work , but there is a reason they are 2W at a minumum.
Gary
About 5 miles south of I-94
www.glaswerks.com
markusw
Post by markusw »
Thanks a lot for your help!! :D
Since the toroidal xfmr I'm going to use gives 270VAC (it's for a preamp only) I have to change the ps string to get the proper voltages for the preamp tubes. The cermet trim I thought to use has 1W and 315V rating. According to the Duncan PSU sims it would "see" about 365VDC on one side and 305VDC on the other. With the trim set to 10k this should be about 0.36W (provided my calcs are OK :wink: ).
Do you think it's safe this way??
Markus
glasman
Post by glasman »
It would probably work for a bit. What I would do is to insert a pot temporarily, set it to the desired voltage, remove and measure the pot and replace it with a fixed resistor.
Gary
www.glaswerks.com
markusw
Post by markusw »
Great idea! Thanks. :D
Why do you think it would work for a bit only??
Sorry for my questions but I'm keen on learning :wink:
Markus
glasman
Post by glasman »
markusw wrote:Great idea! Thanks. :D
Markus
Even at 0.36W you are exceeding the power limits for most smaller trimmers.
Also take into account that the current through that trimmer is going to change as a function of the single applied to the preamp.
Gary
www.glaswerks.com
markusw
Post by markusw »
OK, I have to admit the trimmer I intended to use is not really small with 16mm ;) in diameter but it has 1W rating.
Sorry, what do you mean with "single"? :oops:
Markus
glasman
Post by glasman »
markusw wrote:OK, I have to admit the trimmer I intended to use is not really small with 16mm ;) in diameter but it has 1W rating.
Markus
Sorry, too early in the morning here. I meant signal.....
www.glaswerks.com
markusw
Post by markusw »
I meant signal.....
Ah, makes sense :D
Will check the current with maximum signal present.
Markus
