I did just spend a few minutes messing with it and if the chassis is bolted in slightly crooked it's barely noticeable. Guess that'll work for now.
Not enough words here... needs a picture! The attached drawing shows what I was thinking re recirculation, and the clipped photo of an SVT shows an arrangement very similar to Deric's. Note it appears to have the fan exhausting directly out of the box. I looked at another SVT model in the local GC yesterday, and powered it up to check the airflow. It had the fan mounted against the inside of the front grille, exhausting out through the grille cloth. That set-up is better in that the heated air exhaust is separated from the inlet, which was the open back of the cab (with a perforated metal cover, of course). Pulling heated air back in is like positive feedback- not a good thing.selloutrr wrote:I double checked the direct. I powered on 3 SVT's if i put a piece of paper against the grill it sucks the paper and holds it. so the air flow is outside air - into the amp.
Positive or negative will have a similar effect. The key is air movement so careful planning is important. Just blowing or sucking won't take care of business, the air must flow. I've seen datacenters where one rack pushed hot air on the next rack then the folks are puzzled why one rack overheats and the other doesn't.vibratoking wrote:Cold is just an absence of energy. You want to get the energy out before it has the opportunity to transfer to other materials. Push or pull could be the best depending on the situation, as Bob-I mentioned.
Creating positive pressure inside the box is great if you are going to control the flow with baffles or in some planned way. If not, the effectiveness is lost. You have to have enough in vs out flow for the fan to work optimally. If you starve it on one side or the other, you diminish the effect.
 Yeah, what he said.Alexo wrote:Honestly, I think we're over-thinking this a bit.
As long as there is a modicum of air circulation, things should be fine in a tube amp. Most components are rated for near-boiling point operation, and lord knows the kinds of environments tubes were routinely subjected to back in the days before they became so boutiquey.
Having said that, the cathodes do need to be heated to emit electrons, so don't point a big honking computer fan straight at them. In the case of the OP, I would put it on 'exhaust mode,' as that looks like it would have the most even cooling effect across the power and rectifier tubes.
That fan may be too powerful, looks like the same type I used in my cat's litterbox to push the air out into a dryer hose hooked up to the chimney. Strong enough to create a draft on the other side of the house.
...the answer was obvious in that case, re push/pull, btw
...and I know we want to keep things cool, but dollars to doughnuts, those tubes will sound better HOT.
..and ANOTHER reason is that if you try and pull the hot air out, you need a closed plenum in which to mount the fan, not in the middle of the rear screen grill which is a large open area. In the latter case, you are creating a vacuum behind the fan and cool air from 'outside' will just flow right around and back out through the fan blades..VERY inefficient. By pushing cool air in, you are dispersing the heat in the immediate vicinity with cooler air, albeit not as cool as if ther were a duct leading to an entry point further from the tubes. AND, you should not blow cool air directly on the tubes as that creates a heat imbalance from one side of the tube to the other. Probably the best thing to do would be simply to put a grill in the top of the cabinet ABOVE the tubes and just let the heat naturally rise upwards and out of the cabinet..that's all you really need.alanp wrote:Another reason for push is that if the area is dusty, and the fan is blowing out, air will be drawn in through the other gaps in the cab -- meaning dust will build up in all the other gaps, rather than being drawn through a fan that can be filtered if need be.
In THAT case, take the example of your PC CPU chip with a small, dedicated fan blowing directly on it.Structo wrote:Yes but he is trying to keep the mosfet in his VVR cool so not the tubes per say but the area where the mosfet is mounted.
Well, nothing's been suggested about pressurized air being denser and therefore being able to transfer more thermal energy. (?)Bob-I wrote: Come on folks, I thought there were some engineers here? Thermal engineering anyone?
I suspect the FET is working harder when more "attenuation" is being used. The harder you play it the less work the FET circuit is doing.Deric wrote:I lent it to a buddy for a while and he managed to blow 2 FET'sNot sure what happened as I've never had an issue and I'm pretty sure I play it a lot harder than he did.
