Hello all,
This is an improved version of the Rocket layout.  This will have to do until someone draws it in Visio.
						Rocket layout
Rocket layout
						Re: Rocket layout
he doesnt have the 100pf on the volume
i'm not sure but i think the cathode resistor on v2 is 56k
tubedog has the 220k after the .047...i dont know if that makes any difference?
steve
steve
Re: Rocket layout
Steve,  Thanks for looking.  Yeah, I scribbled (reverse) over the .047 and 220K resistor, mine is wired the correct way. Tubedog also verified the V2 cathode resistors are 1.5K and 68K in another thread.  But I am sure this is where you can tune the amp.
My main concern is actually the wiring of V2 to the board. Specifically the way the 100K plate resistor is wired from pin6 to pin 1 then back to the grid (or pin7)
Does that look correct?
