That is confusing. I would use an hv leg & ground to create a bias voltage. Not sure what they are trying to say on the schematic. I would be careful though - bit like wiring 2 halves of the primary out of phase. Loud buzzing sound followed by the sound of dollar bills leaving your wallet.
I don't see a bias tap on that PT.
So you would have to try a high voltage tap to get it, not sure how well that will work.
Like Bob said, may be phasing issues.
Mark - took a second look at the drawing. Looks like the bias tap is there where they state. I'd measure the ac voltage on the wires before hooking it up though. Missed it last night - too much wine - I was celebrating the birth of my second TW clone. A Rocket - everything from glassy sparkle with a tele, to serious attitude dimed with a strat.
Very interested in building a Rocket Reverb now
Anyway good luck with the build.
Glad you got yours fired up and had some fun with it. I have not built the Normster Rocket reverb using EL84s yet and that maybe something I will do in the future. I like the EL84s at 36watt range great for gigging.
I'll call MC and also check the voltages when I get it wired up.
M Fowler wrote:Ok I went out to MC website and found the real schematic for the PT so my questions are ansered about 120v hook up but what about bias wire?
To me the bias tap is red/grn
CT is red/yel
But look at the note, they have in the middle of the page that states Bias:
red/grn-red/yel.
So its just referenceing bias to ground? Use the red/grn as bias tap at what voltage, not listed anywhere.
You are correct in that red/green is your bias tap which would be filtered and loaded down to ground, which in this case is the center tap red/yellow.
M Fowler wrote:Thanks I will give MC hell for putting me through this or should I have known all this
Years ago I was running lights and recepts in the gear room and watched a superintendant and a foreman scratch their heads over where to hook up the neutral in a single phase transformer. When asked, I volunteered the correct termination point marked XO , which was the center of the winding (120-XO-120). Overlooking the fact that the windings represent a resistive circuit it appeared to be a "dead short" to both of them and they quickly discounted my information and called the manufacturer When I heard this I quickly told them not to mention to the manufacturer that I was in the room as well. These guys had over 50 years experience between them but ... "some things just look funny".
rjguitar had sent me one of those boards as a gift in one of my orders and I loved it so I ordered more from AES great for projects but people need to remember to get the 1/16 turrets when they order these boards.
