llemtt wrote:FUCHSAUDIO wrote:symmetric clipping gives more 2nd order, non-symmetric gives more third order harmonics, especially when driven hard.
actually exactly the contrary
even order harmonics requires an asymmetrical waveform
just take a look at some basic DSP textbook...
anyway talking about even vs odd harmonics it's meaningless, we human beings we perceive sound properties (such as timbre...) from the harmonic spectrum as a whole, it's the structure of the harmonic spectrum and it's evolution over time the relevant aspect
cheers
teo
#1 Circuit Types: Common Cathode Triode
"preamp distortion", used in the revered Bassman, Marshalls, modern tube preamps; frequency response easily made lowpass (sometimes unintentionally) by grid circuit and stray capacitances. Typically 2% distortion when "clean". Clips asymmetrically, although as typically used, cutoff is mushy and more of progressive compression than clipping, and "saturation" is defined by the grid going more positive than the cathode, with a dramatic drop in grid impedance when this happens, perhaps "saturating" the previous triode stage. Lots of even order distortion products until harder clipping reached, then third harmonic rises Almost no fifth or higher order harmonic production until massively over driven.
#2 Single ended Pentode
"output stage distortion", as in smaller, cheaper amps, like Fender Champ, several Gibsons, others.... Asymmetrical clipping, asymmetric distortion from the single ended transformer..... Distinct second and third harmonics. Very noticeable compression effects from screen grid bias drop, power supply sag.
#3 Double ended Pentode
"output stage distortion" as in large amps, including the Bassman..... Push pull operation cancels even harmonic distortion generated in the output stage, so it can contribute only odd harmonics, principally third. Noticeable bias shift when driven hard can cause compression..... Other compression effects include screen grid bias sag, and power supply sag. This may be the origin of the "tube rectifiers sound better" school of guitar amps, as silicon replacement power supply rectifiers give much less sag on signal peaks and higher power supply voltages, so sound cleaner. Symmetric distortion.
#4 Voltage feedback/biased bipolar - Germanium
"Fuzz Face" distortion. Single high gain stage saturates with guitar signal, is biased in a way that can not hard saturate, but can swing a long way towards cutoff without distortion. Low input impedance loads guitar and pre-filters out highs. Asymmetrical clipping, with prominent second harmonic. Prominent third, and noticeable fourth and fifth harmonics. This is the basic circuit in several vintage fuzzes,
