Structo wrote:Nice Tony
I hadn't heard of that tube before but there are many I have not.
The data sheet I looked up said it was a 47 Mu tube and listed it as a "computer tube".
I have an old GE 12AT7 that I had tried before. I didn't seem to notice any difference in gain.
Maybe I'll give it another try.
Thanks Tom
Also keep in mind gain spec by itself is meaningless, even if it is closest to the "real" spec. Just because certian tubes have a mu of 100 doesn't make them any better than another tube that has a mu of 80, because you are ignoring the equally, and perhaps more important, internal plate resistance and transconductance specs. Mu = gm*Rp, so you could have a huge variation in transconductance and plate resistance for the same mu, or gain.
If you tell people that this tube is the one that has the highest "gain", or mu, then they expect it to be the highest gain in circuit, and that is not necessarily the case. The plate resistance has far more impact on tone and actual circuit gain than the gain (mu) of the tube does, when used with "standard" circuit values, because it controls the bandwidth and transient response, in addition to the gain.
Don't confuse gain (mu) with actual gain in real-world circuits. For example, one tube has a gain of 88, and an Rp of 58.8K, while the other one has a gain of 99.9 and an Rp of 83.3K. If you put these into a typical amplifier stage with a plate resistance of 100K, the actual stage gain for the first tube will be 88*100K/(100K+58.8K) = 55.4, and the actual stage gain for the second tube will be 99.9*100K/(100K+ 83.3K) = 54.5.
Not only is the actual gain higher in the tube with lower mu (in some cases), the "real-world" gain is nearly identical. In this case, the internal plate resistance is far more important than the mu of the tube...Tube Geek Talk..
