I'm trying to build up a parts list and am having problems with what kind of input jack am i suppose to use. For a dumble amp, could someone tell me which jacks I should use for the following jacks.
Input
Fets input
Speaker output jacks (main and ext.)
effects loop
						part names for input jacks
Re: part names for input jacks
Input - Closed tip (Switchcraft 12A)
Fets input - Stereo closed tip, closed ring (Switchcraft 14B)
Speaker output jacks:
main - Closed tip (Switchcraft 12A)
ext. - Open tip (Switchcraft 11)
effects loop:
Preamp out - Open tip (Switchcraft 11)
Power amp in - Closed tip (Switchcraft 12A)
The Mouser Number is 502-xx (where xx is the jack type). IOW, a 12A would be 502-12A. If you use Cliff jacks, you're on your own.
effects loop:
Don't think so on te FET input, 14B would be the wrong case, the wrong number of lugs and the wrong function on the jack, IMHO.Normster wrote:Input - Closed tip (Switchcraft 12A)
effects loop:
Gil
