buying g-10
topbrent
Re: buying g-10
Post by topbrent »
Depending on your needs, Antique Electronic Supply has a cool inexpensive, pre-drilled, loaded turret board available. 2mm (1/16) board thickness.
http://www.tubesandmore.com/scripts/fox ... _TAGBOARDS
$10.00 P-HTUR-60
http://www.tubesandmore.com/scripts/fox ... =P-HTUR-60
Available unloaded for $2.95 P-HTUR-A
[img:1253:490]http://www.tubesandmore.com/cemirror/in ... 0_spec.gif[/img]
David Root
Re: buying g-10
Post by David Root »
I use a small 12" bandsaw with a finer blade, the "compromise" one for wood/metal. Then clean up the edge on a belt sander.
rawnster
Re: buying g-10
Post by rawnster »
You guys are funny. It's not that hard to cut. I just made these, and cut them with a hacksaw and C-clamp. :)
[IMG:1600:1200]http://i209.photobucket.com/albums/bb15 ... oards7.jpg[/img]
Re: buying g-10
I use my bandsaw and very slowly push the board through cuts great everytime.
You just need to slow down sometimes. :)
Chad
Re: buying g-10
Post by Chad »
rawnster wrote:You guys are funny. It's not that hard to cut. I just made these, and cut them with a hacksaw and C-clamp. :)
WOW! Those are some cool looking boards rawnster. Are those available at mc master's or somewhere else. They look like carbon fiber from the pic.Thanks, Chad
rawnster
Re: buying g-10
Post by rawnster »
Thanks Chad. I'm not sure about mc master's, but I got the material from turretboards.com.
http://www.turretboards.com/circuit_board_material.htm
1/8th" thick, black....and a little bit of elbow grease. :-)
Chad
Re: buying g-10
Post by Chad »
rawnster wrote:Thanks Chad. I'm not sure about mc master's, but I got the material from turretboards.com.
Thanks Been to turretboards before (Been awhile) and never notice them.May have to pick me up some soon. Thanks again, Chad
RJ Guitars
Re: buying g-10
Post by RJ Guitars »
For protoypes and small quantities you might not shorten your lifespan to do them in the garage on the bandsaw or if you are young and full of spunk, use a hacksaw.. but for large quantities I have found that taking them to a shop and having them knocked out on the CNC machine is the only way to go. If you make a career out of cutting and sanding circuit boards without lung protection it would probably not end all that well for you.
I haven't found any need for thicker than 1/16" as far as strength goes and I agree with everybody else that it is much more friendly than the the other stuff to work into the shape you want. I also prefer carbide tipped drills, it's pretty abrasive stuff.
regards
rj
http://www.rjguitars.net
