Help implementing Loop please Mr Glasman
Hi Gary, or others who may know.
I really need some assurance/help regarding my D/lator type loop.
I have a separate node to supply B+ between PI and O/D nodes.
Q1: Is one node OK for the whole loop?
Q2: The voltage across the first 12ax7 stage of the loop has me worried, at the moment I have 315v at the plate and 18v on the cathode, this seems like a high voltage across the tube, is it correct?
Q3:I know Gary recommends at least 340v B+ which is 25v higher than mine, and I see there's 370v on the first stage in Gary's Rev a Loop but I don't want to adjust my supply until I know it's ok to do so. What should the cathode voltage be at V1 of the loop?
Q4: If I use a switch to bypass the loop, does it need to ground the input of the loop when it is bypassed?
Thanks in advance! I'd really appreciate advice from those with functioning loops built in to their amps, especially you Gary
groovtubin
Re: Help implementing Loop please Mr Glasman
I`ve used ONE node for LOTS of these amp w/D`ators, NO prob`s whatsoever!! I keep my NODES in series too btw... Only separate if B+ too low such as a Traynor YBA-4......... Q2, if that`s the CLEAN FIRST stage, something is WRONG, Q4, FIX the FIRST problem at stage ONE first.... Open plate, or bad tube...grumpy wrote:Hi Gary, or others who may know.
Q2: The voltage across the first 12ax7 stage has me worried, at the moment I have 315v at the plate and 18v on the cathode, this seems like a high voltage across the tube, is it correct?
Q3:I know Gary recommends at least 340v B+ which is 25v higher than mine, and I see there's 370v on the first stage in Gary's Rev a Loop but I don't want to adjust my supply until I know it's ok to do so. What should the cathode voltage be?
Thanks in advance! I'd relly appreciate advice from those with functioning loops built in to their amps, especially you Gary
Thanks Groovtubin, but I'm asking about the first stage of the loop, not the whole amp.
I'm no amp guru, I just need to know some test/reference points for my own peace of mind. Gary has 370v on the equivalent plate in his Rev a loop schem , but what should the cathode voltage be? It's the voltage across the tube that concerns me most
This info would really help me sort this out for myself.
Cheers, Grumpy
Cheers, Grumpy
- glasman
The "real" deal used two supply points. I would suggest dropping a parallel string off of the screen voltage point (after the choke).grumpy wrote: Q1: Is one node OK for the whole loop?
Well once again, according to masurement data that I have seen from the d-lator, the cathode follower was much higher (+350v). You are probably reasonably safe at 315. The stage doesn't offer gain, only a buffering actiongrumpy wrote:
The cathode voltages will range from about 16 to a little over 20 depending on the plate voltage. Best bet still is to have a separate string off of the screen position. Then you can adjust only that section for the best results and it will not effect the rest of the stages.grumpy wrote:
Probably not necessary but always a good idea, that way you keep any extra garbage off the power supply.grumpy wrote:
Gary
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
Thanks Gary, that helps a lot.
There you go, 370v at the plate, 20 at the cathode. That's 350v across the tube!
As I said, I'm no tube guru for sure, but I would have been convinced that those voltages exceed the specs for the tube. I thought 300v was the max? I probably don't know how to read spec sheets properly.
Thanks again Gary, cheers from Oz, Grumpy
Wrong....
The cathode follower was last in the string. The measurement I had was 257v on the cathode follower.
B+ > 15k dropping> 33uf cap >100k dropping> 33uf cap
Gary, you knew that!
- glasman
Not on every one!!dogears wrote:Wrong....
www.glaswerks.com
www.glaswerks.com
- glasman
Given that 257 volts on the last point. The node at 15K and 100K would be about 360 volts.dogears wrote:Wrong....
Gary
www.glaswerks.com
www.glaswerks.com
Really? How so?? The one in question was an incorrect hand drawn... no???
glasman wrote:Not on every one!!dogears wrote:Wrong....
- glasman
You are probably right, I stand (or in this case sit) corrected.dogears wrote:Really? How so?? The one in question was an incorrect hand drawn... no???
First tap recovery second tap cathode follower.
Gary
Gary
www.glaswerks.com
www.glaswerks.com
Thanks Scott and Gary for sharing what you know. This has helped me a lot!
Cheers from rainy Oz, John
