I'm starting to built a 3 channel amp, for the first channel i will use a bandmaster clone, for the other two channels i will use the ODS 101 circuit.
What is the best send-return circuits for this type of amp?
i use the second clean (dumble circuit) for rock and roll/blues crunch, is this possible? with PAB? Thanks
3 Channel 3 Question
Re: 3 Channel 3 Question
IME the ODS clean doesn't really have enough dirt for rock/blues crunch, at least the stock ods101 preamp. Perhaps you should build an ODS with two overdrive stages with one or the other or neither active at any given time. That would make implementing a PAB a lot easier.gitbuy wrote:I'm starting to built a 3 channel amp, for the first channel i will use a bandmaster clone, for the other two channels i will use the ODS 101 circuit.
"I never practice my guitar. From time to time I just open the case and throw in a piece of raw meat." --Wes Montgomery
