im building an 18 watt from a pro jr. is there an easy way to add a line in? id like to have a volume control if possible. here is the schematic
http://mhuss.com/18watt/schematics/18wattLite2b.gif
line in on an 18 watt lite IIb
Re: line in on an 18 watt lite IIb
Like for a CD player or something to run into the amp?
Or do you mean a line out?
poweramp in. id be looking to use it as and 18 watt poweramp, both for other preamps, or possibly, if it sounds good, as a wet side of a wet/dry rig.
If you want it all passive, you could do a switched jack just before the PI. If you want a volume control that won't affect your preamp signal when you have no external source, you will have to have a separate box or something to adjust the volume prior the power amp in jack. I did this type of thing for my first build and it works pretty well.
Exact science is not an exact science
i'm guessing the switched jack would work sufficiently. i'll look into that.
