Help on a old Silverface
fusionbear
Hello everybody. I recently worked on an old 73' silverface vibrosonic that gave me fits, but I eventually Blackfaced the inverter circuit and replaced most of the electrolytics. The customer just made me aware that when he plays live with it, the amp is loud and clean, but after a couple of hours of playing, the amp looses half of its volume. Any Ideas? He hasn't returned the amp yet, but will in a couple of days. Any help would be appreciated...
Learning to learn...
Re: Help on a old Silverface
So it's heat related.
Check
Tube(s)
Solder joints
Carbon Comp resistors
Check
Tube(s)
Solder joints
Power transformer, too. See if the voltage drops when it's hot.
Andy Le Blanc
Heck per the experts rust is suppose to make the trannies run cooler and better.
You replaced MOST of the electrolitics....???
