would just like to ask for a few suggestions for an amp using the deluxe reverb transformers I have lying around.I,ve already built a bluesmaster HRM , a high plate and a 100k skyliner [all 100w]
I,ve read a few posts saying that dumble circuits dont really like 6v6,s - so should I forget about trying to build a dumble style amp and just keep it as a deluxe ?I,m going to build this one to put in a small 1x12 combo [ my backs not what it was !]
any help greatly appreciated thanks,
phil
deluxe reverb transformers-which build ?
phillyhudson
bluesfendermanblues
Re: deluxe reverb transformers-which build ?
Phil, You might just as well use 6L6 with smaller and lighter transformers. You could go for a smaller PT delivering 350 rectified Volts on the Anodes, giving you around 25 watt and demanding a smaller OT as well.phillyhudson wrote:would just like to ask for a few suggestions for an amp using the deluxe reverb transformers I have lying around.I,ve already built a bluesmaster HRM , a high plate and a 100k skyliner [all 100w]
phil
IMHO a dumble design likes a clean poweramp, so 6v6s might muddy things up a bit. However, a transistor power amp might also se3rve you needs as long as you build the preamp with tubes.
I am not as experienced with the Dumble amps, but I really like my 6V6 D'Lite 22. It may not be a "true" Dumble circuit but it sounds great to me. I have no use for a 100 watt amp.
bluesfendermanblues
Ditto! I have build an OTS kit from Ceriatone. And after a burn in period and some tweaking - with input and help from the guys at this forum - I've arrived at a tone, that I find satisfying.brewdude wrote:I am not as experienced with the Dumble amps, but I really like my 6V6 D'Lite 22. It may not be a "true" Dumble circuit but it sounds great to me. I have no use for a 100 watt amp.
Being 45 sommers old, I don't have the need for 100 watts. My amp is a 50 watt and I guess a 22 watts would also suit my needs fine. Plus the lower weight would really be appreciated
phillyhudson
thanks for replys - I could use different transformers for 2 6l6's but then I'd have to buy them ! I,ve tried putting a dumble overdrive and hrm tone stack after a basic carlsbro 50 top pre amp with great results so I might just try doing that with a basic fender circuit.
thanks for replys - this forum's been amazingly helpful for me with my builds !
Guitarman18
phillyhudson,
After having built a high plate non HRM and a Bluesmaster (both 100W) like yourself, I've just finished a 6W SE amp with a Champ like power amp and it is a very fun amp to play. Admittedly it hasn't got the 'girth' or headroom of the 100W, but it does have a number of D type characteristics that I imagine it will be pretty nice for recording, practice and possible micro gigs
My advice would be to go for it. The worst case scenario would be that if you don't like it, you could then mod it into a deluxe that has an overdrive channel (for better or for worse). Or if the Deluxe iron doesn't cut it, buy some bassman iron in the future.
Cheers, Paul.
Cheers, Paul.
max_lwedge
I turned a mangled SF Princeton Reverb into what is essentially a BM, sounds really good and is plenty loud. It uses BF Deluxe Reverb iron from MM. I had to tweak to get tone where I like it, but that's always where the magic is. I ended up with 100k V1 and 220k/150k V2. Reverb is close to the single tube seen before on the forum. It does get a little crunchy tuned up really loud, but no complaints. The amp is very portable.
Instead of the full HRM stack, I used a 350K tapped treble pot (from Vibroverb 6G16) as the entire stack, mounted on the back. It has the slope, mid & bass caps flying off the pot, a 22k fixed mid to ground. The tap works out to be a fixed 70k bass pot. Looks scary, but very compact. Presence lives where ground switch was.
Speaker is currently a GL65-12 Heritage, subject to change. I've used NOS Pope (favorite), Brimar and GE 6V6s, at about 435-440v.
Good luck, Max
Good luck, Max
Here is a 2 6V amp.... a loud 22 watts..If you are going to do a 22 watter with the Deluxe transformers I recommend doing an HRM
Tony VVT
Tony VVT
