Anyone use foil tape for shielding in an amp?
Like covering the heater wires or for lead dress?
									Yes, I'm new here..
						- glasman
Re: Anyone use foil tape for shielding in an amp?
Interesting concept.
TR in their early amps used an interesting shield made by wrapping a solid core wire around the signal wire grounding it on the low impedance end. I guess you could do the same thing with heater wires.
But in practice, I have never found a need to do so on heaters (especially if you have enough standoff for the heater wires.
Now on a PCB (like my MatchBox), I used DC heaters, just to make sure .
Gary
.Gary
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
Yea, I built an 18watt from GuitaramplifierPCBs that suggested the same thing, wrap a wire with solid core, seems to work.
									Yes, I'm new here..
						- glasman
As long as you don't ground both end of the wrapSeemoore wrote:Yea, I built an 18watt from GuitaramplifierPCBs that suggested the same thing, wrap a wire with solid core, seems to work.
.  Located in the St Croix River Valley- Afton, MN
www.glaswerks.com
www.glaswerks.com
