Liverpool "Jeanette"
gahult
Post by gahult »
In the 60's people took acid to make the world weird. Now the world is weird , and they take Prozac to make it normal.
Colossal
Re: Liverpool "Jeanette"
Post by Colossal »
Beautifully done Gary, very discreet build and layout. I like the black accent with the tube shields and your version of the voltage control circuit. The name stamped into the chassis is a nice touch. Can't wait t'hear it go!
Best,
Dave
DustyBadlands
Post by DustyBadlands »
Looks great Gary. How's she sound? I thinking LP for my next build. :D DB
gahult
Post by gahult »
Thanks to both. :)
Dusty,
It sounds good. I don't have the feedback I get with the guitar plugged into my Express. Why, I don't know but, it doesn't seem as sensitive in that regard.
I do seem to have an issue with the brite switch. I don't notice much change in sound in any position.
If anyone has some input on that I would appreciate it.
Thanks again,
Gary
Gary,
Nice build as usual there. :) I just got home, I had been trying to open these pictures at work and of course they blocked them on me. So you have the VVR on the back side to keep the traditional Liverpool look, right? Nice amps your family will be able to pass down, Gary.
gahult
Post by gahult »
Mark,
Thanks,
Yes, I put the VVR back there for that reason. I figure once I set the level I'm pretty much good to go. Heck, I can always reach back the to crank it up...or down some. :)
I did it the same way on my Express but, I did put it up front on the Rocket as there is the extra hole.
Gary
Gary,
I miss playing my amps but they say the river is going to crest at 43 feet this time which is higher then what Fargo/Moorhead already went through. I got the equipment out of the basement crammed in right behind my office chair hard to turn around. :)
The sewer manhole covers blew off near my buddy's house so I have my sewer plug ready just incase they start backing up again. The area I live in is high and dry but sewer backup is the main problem. Should move back to Phoenix.
gahult
Post by gahult »
Update on the brite switch.
Checked wiring...OK.
Wife went to work...turned up to full power on VVR...brite switch works OK.
Just didn't know that the lower power had a bearing on it as it does.
Gary
Kregg
Post by Kregg »
Very Nice Gary.
P.S. Noticed that you're in Marion, I was born and lowered in Cadillac. :wink:
"A man with an experience is never at the mercy of a man with an argument." Hilmar von Campe
sst4270
Post by sst4270 »
Very nice work Gary. Can't wait to see her in a cabinet and hear some clips.
Steve
drhulsey
Post by drhulsey »
Great lookin' amp :D I like the way you put the IEC in at 45 degrees. I put mine in at 90 degrees, but had to do a little trimming.
Not many of us can build 'em that nice with just one arm 8)
Get well soon :!:
Tim
Tubetwang
Post by Tubetwang »
Yup! Good call on the IEC Gary!!
I like it!!!
fishy
Post by fishy »
Gary,
Nice build.
The VVR is right up against the OT secondaries - no issues with that?
Looks like a great way to implement it.
Thx for posting the voltages too...... some interesting differences across the builds.
Kregg
Post by Kregg »
Gary, where'd you get the chassis?
gahult
Post by gahult »
Thanks.
Pete,
I put my VVR in the back on Alan's Express the same way. I had not had any issues with either build with the implementation. :)
Kregg,
The chassis is from Allyn. I think he has some in stock if you need one.
Gary
