Swamp Thing Amp
Swamp Thing Amp
Since I am snowed in I decided to start on a single ended amp.  I had order some surplus swamp thing trannies so I got started.
This is an 8 ohm OT. I need two .68u caps for the board yet and start on my filter caps next.
						Re: Swamp Thing Amp
Looking good!
That chassis looks huge. I am not used to having that much room with which to work in. Is it about 5 watts or so?
What are the specs on Swamp Thing trannies?
Re: Swamp Thing Amp
mcrracer,
I had two of these chassis sitting around. There Hammond steel 16x8x2 so yes they are larger than what I would normally have used but I have a lot of empty head cabs sitting around so I started on a Route 666 with one and this amp for the other.
The trannies are on clearance at MOJO without any specs but there is a link to Ax84 guy with pictures of his build. They note the tranny is similiar to a champ with 8 ohm. The PT had not info. I make a schematic for the PT and OT from pictures of a build on the net and then got started. I plan to measure the secondaries soon.
Re: Swamp Thing Amp
Here is some info on the trannies from mojotone.com under surplus section.
Sundowner/Swamp Thing SE Output Transformer
Part Number: 7024100
Great Champ 8 OHM Output type
Sundowner/Swamp Thing Power Transformer (for SE Application)
Part Number: 7024101
						Re: Swamp Thing Amp
I wish I new how to use visio better so I could make a layout of this schematic because it is kicking my arse right now.  Had to resharpen my pencil twice now drawing.
Where is BnWitt when you need him, the layout king.
Re: Swamp Thing Amp
How do you like the triode/pentode switch?
What does it do tonally or sonically?
Ooops, I guess you probably don't have it going yet.
Re: Swamp Thing Amp
No I am still working on it.  Got some more done tonight.  Should be done soon.  It is a maze of wires due to poor layout planning, oh well live and learn.  Also, I don't think the board layout was the best.  I should have waited and designed that myself.
						Re: Swamp Thing Amp
Very nice work. Working in a larger chassis must make things easier. I guess I have to graduate up. I too put this amp on the short list for this Spring. I look forward to hearing yours. Good job! More pix if you can...makes me feel as if I was there.
						Re: Swamp Thing Amp
Mark,
What is the turret board material made from?
I can't wait to hear that thing!
Re: Swamp Thing Amp
I would guess garolite, I bought 4 boards from turretboards.com to have on hand.  I got the way too small turrets though.  Next time I will get larger stock and double turrets.
These small boards have been good for capacitor mounting though. I have got to start using can caps in some of my builds.
Re: Swamp Thing Amp
Hi Mark,
I'd really be interested to find out what kind of voltages you are getting out of that PT?
A guy can't go wrong for the price if the voltage is there....
Thanks,
Thanks,
Re: Swamp Thing Amp
I should be building that amp instead of lurking on the Forum
I will test soon, hopefull it won'tl blow-up!
Re: Swamp Thing Amp
Secondaries 366-0-366 is what I got? with 508v at B, 485v at C, and 505v at D.
Not working yet, got problems oh well I will go back over it some more. Should have built a champ.
Re: Swamp Thing Amp
Thanks Mark,
Fairly high voltage isn't it....
Good luck getting it running.
Thanks,
Thanks,
Re: Swamp Thing Amp
I don't know how you guys use visio so well, my first attempt is bad.
I also need more shape files for the PT/OT holes and things.
