Precision PSU
Precision PSU
As I understand it, the precision PSU is part of the later dumbles. I have a few questions about this:
- I suppose two 47uF in series reacts faster than one 22uF. Is this right?
- Is there a difference in performance between two 47uF in series, and two 10uF in parallel, as long as voltage rating is observed?
- How would a 22uF with say a 100nF cap in parallel perform compared to this?
Thanks!
soje
Thanks!
soje
Re: Precision PSU
With the notion that caps in parallel add their values, and in series you need to take the reciprocal of the sum of the reciprocals:soje wrote:As I understand it, the precision PSU is part of the later dumbles. I have a few questions about this:
Thanks!
soje
1. Two 47uF in series are equivalent to a single 23.5uF, so that VS 22uF is a bit of a wash
2. Two 47uF in series gives you 94uF and two 10uF in parallel 20uF. Big difference here
3. A 22uF with a 100nF cap in parallel gives you 120uF
Gil
Re: Precision PSU
A 100nf cap is .1uf
Unless the nf was a typo a 22uf plus a 100nf would equal 22.1uf.
Re: Precision PSU
Ah, of course! I didn't even see the n instead of u, as nF is non standard in the US -- but it is a perfeclty valid unit nonetheless. The only reason to add a small cap in parallel with a large cap is to, supposedly, smooth things out some.Structo wrote:A 100nf cap is .1uf
Gil
Re: Precision PSU
Sorry Gil I didn't mean to correct you, I thought maybe it was a typo.
Re: Precision PSU
Oh too late for that now!Structo wrote:Sorry Gil I didn't mean to correct you, I thought maybe it was a typo.
Gil
Re: Precision PSU
Here's the real typoayan wrote: 2. Two 47uF in series gives you 94uF
Gil
www.RedPlateAmps.com
Re: Precision PSU
I think you have another typo there Gil, two 47uf in parallel gives 94uf. Two 47uf in series gives 23.5uf as you said in answer to #1, and that is close to the same (well, within ~20%) as two 10uf in parallel, giving 20uf.ayan wrote:With the notion that caps in parallel add their values, and in series you need to take the reciprocal of the sum of the reciprocals:soje wrote:As I understand it, the precision PSU is part of the later dumbles. I have a few questions about this:
Thanks!
soje
Gil
I think the only point in using two larger caps in series is so that a lower voltage rating can be used, lowering the per part cost, at the expense of more parts. I've wondered about the ESR of the two caps in series, paralleled with the balancing resistors against the ESR of a single cap and what that means.
MPM
Re: Precision PSU
That's the right reasoning about the series caps.martin manning wrote:I think the only point in using two larger caps in series is so that a lower voltage rating can be used, lowering the per part cost, at the expense of more parts. I've wondered about the ESR of the two caps in series, paralleled with the balancing resistors against the ESR of a single cap and what that means. MPM
On the ESR question, at audio frequencies and the relatively modest currents we're talking about, the higher ESR means pretty precisely dick. You worry more about ESR for high-frequency, high-current-slew-rate applications like CPU power supplies.
... just my stupid opinion, of course.
Re: Precision PSU
I agree, ESR and ESL is usually measured at 100 kHz, but in the case of paralleling say a ceramic and an electrolytic, you won't get a true parallel value. Since the caps are not ideal, you still get a steering of lower frequencies through the electrolytic, and higher frequencies through the ceramic. You still have essentially the same electrolytic cap value at the lows, and the ceramic value at the highs. To obtain a true parallel or series vaule, it's best to use the same cap types be it polys, ceramic, tantalums, plastic (mylar), electrolytics, etc.
Re: Precision PSU
Too many typos!heisthl wrote:Here's the real typoayan wrote: 2. Two 47uF in series gives you 94uF
Gil
Gil
Re: Precision PSU
I might be trying to learn everything at once. Time to lay off of the coffee
I guess my questions can boil down to this:
Disregarding price, is there any reason to use 2 caps in series, instead of just 1 cap?
Somehow Dumble amps doesn't strike me as budget amps, so I wonder why he used the "precision PSU" with more components.
Am I making sense?
Regards
soje
Am I making sense?
Regards
soje
Re: Precision PSU
To double the voltage is can handle.soje wrote:Disregarding price, is there any reason to use 2 caps in series, instead of just 1 cap?
Re: Precision PSU
Interesting also is the use of balancing resistors in Dumble supplies.
Sometimes called equalizing resistors.
This is done to control the voltage sharing across each cap in series and makes the voltage equal on both. It also helps counter leakage of the caps.
As a side benefit, they also function as bleeder resistors, discharging the caps at shutdown.
