I asked earlier about SS rectifiers in a 5f1/2 circut and think I have crossed that hurdle. My goal is to build a low powered recording/bedroom amp, my 5 watters are just too loud turned up. I'm am not looking for much headroom or cleans from this amp. I'm looking for something close to 1/2-1 watt. So I thought why not build a 6K6 powered amp.
What I have right now is a Champion 600 Reissue transformer (the specs on the back are 275v 6.3v). It does not have a center tap or a 5v tap.
I was hoping to use a champ circut 5c1/5e1/5f1. My question is will one of these circuts with a SS rectifier and this transformer have too much plate voltage for a 6k6GT? And also is an octal or 9pin preamp tube best for something with a 6k6GT. Are there any circuts out there made for this tube I could use? Or any prefered mods on a champ circut? Any links to specs for a 6k6? Thanks for any help.
						Circut optomized for a 6k6 output tube?
Re: Circut optomized for a 6k6 output tube?
In the 60's people took acid to make the world weird. Now the world is weird , and they take Prozac to make it normal.
				Andy Le Blanc
6k6 has a design center max plate voltage of 315 v
the typical operating values of 285 v at the plate and will make around
10 watts as a push pull pair with a 12k load resistance.
The RCA data also gives A1 operating conditions where plate and screen are
supplied with 100v and a 12k load with a single tube making 0.3 watts.
so if the right OPT where found you could make a P-P 6k6 based 1W
amp, maybe even with a transformerless power supply, very retro.
lazymaryamps
						- Voodoo_Man
You can add another node to your PS at the front. Compare the first schematic to this one. You would adjust R10 upwards to lower your B+.Schwebel wrote:What I have right now is a Champion 600 Reissue transformer (the specs on the back are 275v 6.3v). It does not have a center tap or a 5v tap.
God Bless,
									"Arnold, where's my tax refund???"
