Solid State rectifier in a 5F1 circut?
I've come across a power tranny I'd like to use for a 5F1 project, but it does not have a 5v tap for a tube rectifier. I was wondering if anyone had a schematic and/or layout for a 5F1 with a solid state rectifer. Or knows how to incorperate a SS rectifier in that circut.
						- Voodoo_Man
Re: Solid State rectifier in a 5F1 circut?
Look here>>>>http://en.wikipedia.org/wiki/Diode_bridgeSchwebel wrote:I've come across a power tranny I'd like to use for a 5F1 project, but it does not have a 5v tap for a tube rectifier. I was wondering if anyone had a schematic and/or layout for a 5F1 with a solid state rectifer. Or knows how to incorperate a SS rectifier in that circut.
God Bless,
- Voodoo_Man
I edited one of my schematics to give you a better idea of how to proceed.
1N4007 diodes are fine or use a FWB package. The R & C values are for example only. I left the DC heaters, you may not want those.
Good Luck & God Bless,
I plugged a SS rectifier into the 5y3 socket of my homebrew champ for a jam once.  An arch occurred thru the 6v6 socket and I had to change it and the tube.  May have been coincidence but I think the increased voltage put it over the edge.  It was already too high.
Using SS is fine as long as you compensate the PS voltage somehow. With the low current draw of that amp you could use a 10watt resistor directly off the output of the diodes. Don’t use a bridge setup since that will provide still higher voltage.
I actually use a 1k resistor like that off of my tube rectifier. My voltage was too high from the power tranny not being the most appropriate. It reduced my plate from about 420 to 340 when biased at 12 watts.
I suggest looking at Module 7, Chapter 4 of NEETS... http://www.phy.davidson.edu/instrumentation/NEETS.htm
You have a choice between a bridge rectifier and conventional full-wave rectifier. See which one will work for you.
- Voodoo_Man
I made the assumption that your PT did not have a center tap. If it does, you can use a "full wave (two diode) C.T., rectifier circuit". Look at the PS for the Express on this site. If it doesn't, then you are kinda stuck with the circuit I posted. Anyway, here is a layout I found for a Princeton with a SS rectifier. Very similar to the Champ you want to build.Schwebel wrote:I've come across a power tranny I'd like to use for a 5F1 project, but it does not have a 5v tap for a tube rectifier. I was wondering if anyone had a schematic and/or layout for a 5F1 with a solid state rectifer. Or knows how to incorperate a SS rectifier in that circut.
God Bless,
Thank you for the layout, pretty much what I was looking for. That layout has vastly different filter cap values than a stock 5f2. is this because of the use of a SS rectifier? Also what is the purpose of the 5k 2watt resistor across filter cap 1 and 2? Sorry for the noobish questions.
						- Voodoo_Man
And yet another. I think "Richie" designed this.
god Bless,
						god Bless,
						- Voodoo_Man
Those control the voltage of various supplies (nodes) I call them rail dropping resistors. Don't sweat the cap values.Schwebel wrote:Thank you for the layout, pretty much what I was looking for. That layout has vastly different filter cap values than a stock 5f2. is this because of the use of a SS rectifier? Also what is the purpose of the 5k 2watt resistor across filter cap 1 and 2? Sorry for the noobish questions.
If you use that FWB with the same transformer that would give the correct voltage with a tube you will have way too high a B+.Voodoo_Man wrote:I edited one of my schematics to give you a better idea of how to proceed.
Use a two diode bridge and the center tap to ground. The voltage will still be a little high, but not the craziness that you're talking about.
Instructions...I don't need no stinkin instructions
						- Voodoo_Man
joebob, your post gave me an idea for a signature.joebob wrote:Here's a little theory on what you want to do.
Dave
God Bless,
"Arnold, where's my tax refund???"
