Got it cranked up yesterday. Had a couple small hitches, I guess a Fil wire slipped out when going over them again and a bad AX7, but other than that it pretty much just started right up. Still pretty much voicing it right now. Working on getting it set up for an LP and a Strat.
I have the first tube paralleled (split the cathode), half power switch and the cathode on V2 bypassed. Not sure if I'll keep the half power. By the way if you go to half power, kill the ground to two cathodes on opposing power tubes, with the same speaker load you increase the impedance of the OP transformer one step?
Anyway here are a couple of pics.
RJ thanks for bringing the chassis and transformers to Tulsa with you.
BL
Blast Of....Got'er Dun
